Pixy 2 CMUcam5 Smart Vision Sensor
SKU 102991074
Pixy2 is the second version of Pixy. It's faster, smaller and more capable than the original
Pixy, adding line tracking/following algorithms as well as other features.
Here's what we've added to Pixy2:
Pixy2 detects lines, intersections and small barcodes, intended for line‐following robots
Improved framerate – 60 frames‐per‐second
Tracking algorithms have been added to color‐based object detection
Improved and simplified libraries for Arduino, Raspberry Pi and other controllers
Integrated light source
And of course, Pixy2 does everything that the original Pixy can do:
Small, fast, easy‐to‐use, low‐cost, readily‐available vision system
Learns to detect objects that you teach it
Connects to Arduino with included cable. Also works with Raspberry Pi, BeagleBone and
similar controllers
All libraries for Arduino, Raspberry Pi, etc. are provided
C/C++ and Python are supported
Communicates via one of several interfaces: SPI, I2C, UART, USB or analog/digital output
Configuration utility runs on Windows, MacOS and Linux
All software/firmware is open‐source GNU‐licensed
All hardware documentation including schematics, bill of materials, PCB layout, etc. are
provided
Typical Functions Overview
Seven color signatures
Hundreds of objects
Teach it the objects you’re interested in
Pixy2 "tracks" each object it detects
color code
Detecting and tracking lines
Detecting Intersections and "branching"
Give Me More Info
Part List
Pixy 2 CMUcam5 Image Sensor
1
FC‐10P to FC‐6P Cable
1
Screw Package
1
ECCN/HTS
ECCN
6A993
HSCODE
9031900090
Technical Details
Dimensions
42mm x 38mm x 15mm
Weight
G.W 20g N.W 10g
Battery
Exclude
Processor
NXP LPC4330, 204 MHz, dual core
Image sensor
Aptina MT9M114, 1296×976 resolution with integrated image flow
processor
Lens field‐of‐view
60 degrees horizontal, 40 degrees vertical
Power consumption
140 mA typical
Power input
USB input (5V) or unregulated input (6V to 10V)
RAM
264K bytes
Flash
2M bytes
Available data outputs
UART serial, SPI, I2C, USB, digital, analog
Integrated light source, approximately 20 lumens
https://www.seeedstudio.com/Pixy‐2‐CMUcam5‐Smart‐Vision‐Sensor‐p‐3091.html 9‐6‐18
很抱歉,暂时无法提供与“102991074”相匹配的价格&库存,您可以联系我们找货
