102991182
102991182
    SEEED(矽递科技)
    街机游戏套件 micro:bit Microsoft MakeCode,Python MCU
102991182 数据手册
      Kittenbot Meowbit Card‐sized Retro Game Computer  SKU 102991182  Meowbit is a card‐sized graphical retro game computer with allows you coding with Makecode arcade and Python. In other words, it can use combines game programming with hardware devices. Meowbit is a card‐sized graphical programming video game console designed for teenagers. It contains 1.8' full‐color screen, 6 x programmable buttons ,1 x buzzer, built‐in light sensor, temperature sensor, SD card slot (For external storage), multiplayer connector and edge connector. Especially the edge connector could access most micro:bit expansion boards. We recommend using Robot:bit for Mewobit, it can help you create a robot quickly. Features ● 160 x 128 full‐color TFT LCD provides a more vivid interactive interface ● Easy to use graphical programming, learning while playing experience through game programming ● Cross‐cutting functions including hardware and software ● Abundant hardware resources made infinite possibility possible ● Support multi‐platform including Makecode arcade, Kittenblock, scratch3.0, MicroPython; support multi‐language ● Support diagraming, showing the data changing of the sensors more intuitive Hardwares 1. Charging/work indicator 2. Light sensor 3. Power switch 4. Programmable led x 2 5. Reset 6. DFU mode button 7. 160 x 128 TFT color screen 8. Temperature sensor 9. Direction button x 4 10. Buzzer 11. Button A/B 12. Compatible with micro:bit’s 40 PINs Goldfinger 13. USB program download port / charging port 14. SD card slot (Use for store programs or extend wireless modules) 15. Multiplayer Connector 16. mp6050 gyroscope 17. 3.7V lithium battery package interface 18. MCU 19. 2MByte SPI‐flash (default download Unicode character table) 20. Signature area Parameters ● MCU:STM32F401RET6, 32‐bit ARM Cortex M4 core ● Operating voltage: 3.3V ● Supply voltage:USB(5V), Lithium battery pack(3.7~4.2V) ● Output current: 500mA(max) ● Dimensions: 52x76x12(mm) ● MacOS, Windows7 and above Programming mode ● Makecode Arcade graphical programming mode ● MicroPython programming mode Scenarios Part List    Meowbit x 1 Silicone Sleeve for Meowbit x 1 Not included: 6x40x20mm 3.7V 450mAh Lithium Ion Battery with JST 2.0mm PH, 2‐Pin connectorx1 ECCN/HTS ECCN  3A991.a  HSCODE  8543709990  USHSCODE  85177000      https://www.seeedstudio.com/Kittenbot‐Meowbit‐Card‐sized‐Retro‐Game‐Computer‐p‐3800.html/5‐16‐19
102991182 价格&库存
很抱歉,暂时无法提供与“102991182”相匹配的价格&库存,您可以联系我们找货
  • 1+351.481021+45.50226
  • 1+388.686101+50.27440
