102991319
102991319
    SEEED(矽递科技)
    箱 塑料 - ABS 白色 手持式 X
102991319 数据手册
ABS Electrical Box for Raspberry Pi 4B SKU 102991319 ABS Electrical Box for Raspberry Pi 4B is a Raspberry Pi case contains a single fan to keep cooling. It can be hanged on the wall and the Pi 4B can be seen via the transparent observation window. Use for home’s electric system or some industry occasion. Key features • • • • • Transparent Observation Window Mounting hole for hanging on the wall Single fan Compatible with Raspberry Pi 4B Use for home's electric system or some industry occasion Description This case is suitable for Raspberry Pi 4B. It is made of ABS material. The bright spot of the case is the transparent observation window. Through the window, you can view the operating state of the Raspberry Pi. Besides, a single fan is added to help RPi 4B to reject the heat. A mounting hole is designed for the case hanging on the wall. This electric box can carry RPi 4B for some home’s electric system application and industry uses. If you want to figure out the assembling method, please view the wiki. Specification Part list • • • • 1 x ABS Electrical Box for RPi 4B 1 x Single Fan with heat sink 1 x Screw Driver 1 x Aluminum heat sink pack for RPi 4B ECCN/HTS HSCODE 3926909090 UPC https://www.seeedstudio.com/ABS-Electrical-Box-for-Raspberry-Pi-4B-p-4321.html/12-6-19
102991319 价格&库存
很抱歉,暂时无法提供与“102991319”相匹配的价格&库存,您可以联系我们找货
