102991321
102991321
    SEEED(矽递科技)
    CANBED - ARDUINO CAN-BUS DEVELOP
102991321 数据手册
CANBed - Arduino CAN-BUS Development Kit (Atmega32U4 with MCP2515 and MCP2551) SKU 102991321 CANBed - Arduino CAN-BUS Development Kit carries an Atmega32U4 chip and MCP2515, MCP2551 CAN-BUS controller and transceiver to realize the CAN-BUS communication protocol on a single board without other MCU to control, it is a CAN-BUS Development Board itself! Note We have already released CAN-BUS Shield V2 which is an Arduino shield based on CAN-BUS. This CANBed - Arduino CAN-BUS Development Kit carries an Arduino chip - Atmega32U4, which means it combines the CAN-BUS Shield and Arduino Development Board together on one single board. Key Features     Atmega32U4 with Arduino Leonardo bootloader on the board MCP2515 CAN Bus controller and MCP2551 CAN Bus transceiver OBD-II and CAN standard pinout selectable at sub-D connector Compatible with Arduino IDE Description CAN-BUS is a common protocol and widely used in industry due to its long travel distance, medium communication speed, and high reliability. Now you can realize a CAN-BUS project through this tinny little development board. Different from CAN-BUS shield series that we have released, CANBed - Arduino CAB Bus Development Kit embed an Atmega32U4 chip, which means you don’t need to add other jump wires to another Arduino Board, it is an Arduino board itself! Because of the Atmega32U4 onboard chip, this board has rich resources in pins. As a matter of fact, there are 18 pins based on core chip set up on the board, which include digital pins, analog pins, UART, and I2C interface. Besides, this CANBed adopts MCP2515 CAN Bus controller with SPI interface and MCP2551 to achieve the CAN-Bus capability. There are also two kinds of CAN Bus interface for various demands which are sub-D9 connector and terminal block interface. They would fit all your need in the connecting method. This CAN-Bus development board is perfectly compatible with Arduino IDE. With the help of the Arduino CAN-Bus library, you will save plenty of time for your CAN project. Specification Parameter Value MCU Atmega32U4(with Arduino Leonardo bootloader) Clock Speed 16MHz Flash Memory 32KB SRAM 2.5KB EEPROM 1KB Operate Voltage(CAN-BUS) 9-28V Operate Voltage (MicoUSB) 5V Input Interface sub-D Hardware Overview 1.9x2 IO Pin OUT: The IO of Atmega32U4 is listed out here 2.Atmega32U4: The master of the entire module mainly used to store data on the TF card or transfer data to the computer through the type C cable. In addition, since it's Arduino compatible, you can use it to implement some simple controls, such as triggering a buzzer alarm when the speed exceeds a certain value. A: Reset Button: Reset the on-board Atmega chip. 3.Micro USB connector for programming 4. ICSP Header for uploading bootloader 5.CAN RX/TX Indicator 6.sub-D connector or Terminal for CAN Bus D-Sub CANbus PinOut pin# Signal names Signal Description 1 Reserved Upgrade Path 2 CAN_L Dominant Low 3 CAN_GND Ground 4 Reserved Upgrade Path 5 CAN_SHLD Shield, Optional 6 GND Ground, Optional 7 CAN_H Dominant High 8 Reserved Upgrade Path 9 CAN_V+ Power, Optional 7.Switch for the 120Ω terminal resistor for CAN Bus If you use this slaver at the end of the CAN bus, you need to solder a 120Ω resister between the two pad, if not just leave them alone. 8.Grove connector for UART 9.Grove connector for I2C Part List  CANBed PCBA  sub-D connector  4PIN Terminal  4PIN 2.0 Connector x 2  9x2 2.54 Header x 1  3x3 2.54 Header x 1 ECCN/HTS HSCODE 8543709990 UPC  https://www.seeedstudio.com/CANBed-Arduino-CAN-BUS-Development-Kit-Atmega32U4-with-MCP2515-and-MCP2551-p-4365.html/12-6-19
102991321 价格&库存
很抱歉,暂时无法提供与“102991321”相匹配的价格&库存,您可以联系我们找货
