102991334
102991334
    SEEED(矽递科技)
    SEEED IOT PROGRAMMABLE BUTTON FO
102991334 数据手册
        Seeed IoT Button for AWS ‐ Cloud Programmable Dash Button SKU 102991334 The Seeed IoT Button For AWS is a Wi-Fi-based, programmable button that deploys the AWS IoT 1‐ Click service. The simple Wi-Fi device is easy to configure and designed for developers to get started with AWS IoT Core. Features         AWS IoT 1‐Click service Single/Double/Long Press Click Events Onboard Power/Event/Wi-Fi Configuration Status LED Equipped with Realtek RTL8720DN, dual-band 2.4Ghz / 5Ghz Wi-Fi Removable and Chargeable NCR18650B Battery Battery polarity reversed protection and indication USB Type-C Charging Stickable Bracket     Attention Please kindly know that there is no battery in the package, while the battery is available in regular convenience stores and customers need to prepare themselves. And what we propose is Panasonic NCR18650B Flat Top 3400mAh Battery. Photo Reference for Panasonic NCR18650B Flat Top 3400mAh Battery Description The Seeed IoT Button For AWS is a Wi-Fi-based, programmable button that is easy to configure and simple to use. You can use the Seeed IoT Button For AWS to capture quick customer feedback without burdening customers with time-consuming questionnaires. It is designed for enterprises and developers to easily integrate with existing business workflows and systems using the AWS IoT 1-Click service. This IoT Button is fully compatible with the official AWS IoT 1‐Click iOS app and Android app. The battery for this device is NCR18650B chargeable Li-ion battery. There is also a stickable bracket for this IoT Button. Customers can stick it on the wall or other surface and easily put the IoT Button in and get out from the bracket. The Seeed IoT Button for AWS supports three types of clicks: single, double, and long press, and 3 LEDs for different indications. Applications      AWS IoT Button Home Control Integrate with third-party APIs One-click to order takeout button Remote control for Netflix     What can Seeed IoT Button For AWS do Scenario Methods Hotel By using different types of clicks to differentiate what services do the tenant wants. Restaurant Using different types of clicks to indicate where the customers are sitting and what food they ordered. Manufacture Factories Different types of clicks to trigger different manufacture problems that appeared. Near Airports By installing the IoT Button near the Airports, people from the neighbourhood can input different feelings towards the noise level. For example, Acceptable, no feeling or annoyed. Setup, Document and Support Please visit our wiki for more information about Seeed IoT Button For AWS. Specifications   Parameter Value Size 92*32*25mm MCU Realtek, RTL8720DN: 20MHz Cortex M0; 200MHz Cortex M4F Flash 4MB Button 100,000 Cycles LED RGB Wi-Fi 802.11 a/b/g/n 2.4GHz & 5GHz   Bluetooth BLE 5.0 Battery 3.6V Li-ion 18650 Rechargeable battery Charging Interface USB Type-C Charging Current 500mA Charging time 4-6 Hours(According to battery capacity) Battery Protection Overcharge, Overcurrent, Over-discharge, and Reverse polarity protection Firmware Update Support OTA Hardware Overview Part List     Seeed IoT Button For AWS x 1 Stickable Bracket x 1 User Manual x 1 Triangle Plastic Pry Opening Tool x 1     ECCN/HTS HSCODE 8536500000 UPC FCC 1 CE 1                               https://www.seeedstudio.com/Seeed‐IoT‐Button‐for‐AWS‐p‐4527.html/4‐27‐20
102991334 价格&库存
很抱歉,暂时无法提供与“102991334”相匹配的价格&库存,您可以联系我们找货
