103020293
103020293
    SEEED(矽递科技)
    GROVE - 8 CHANNEL I2C MULTIPLEX
103020293 数据手册
  Grove ‐ 8 Channel i2c multiplexer/I2C Hub (TCA9548A) SKU 103020293 Grove - 8 Channel I2C Hub is based on the TCA9548A I2C multiplexer chip, support the expansion of 8 I2C devices with the same I2C address.  We've already released the Grove - I2C Hub (4 Port) and the Grove - I2C Hub (6 Port). Wait, still not enough? Well well, we know you are seeking more. Here you are, we present you the Grove - 8 Channel I2C Hub. More importantly, this is more than just a superposition of port quantities. As we all know, I2C devices must use different addresses in the same bus system, even use the Grove I2C Hub (4 or 6 port), the rule is still the rule. However, with the help of Grove - 8 Channel I2C Hub, you can plug up to 8 same‐address I2C devices to the same Grove I2C system. All thanks to the TCA9548A I2C Multiplexer Chip. It adopts time-division multiplexing technology so that the same controller can control 8 I2C devices with the same address. No more worrying about address conflicts. Features    8 Grove I2C Port Support multiple devices with the same I2C address Support 3.3V/5V System Part List   Grove - 8 Channel I2C Hub (TCA9548A) x1 20cm Grove Cable x1 ECCN/HTS HSCODE UPC 8543909000                                 https://www.seeedstudio.com/Grove‐8‐Channel‐I2C‐Hub‐TCA9548A‐p‐4398.html/1‐14‐20
103020293 价格&库存
很抱歉,暂时无法提供与“103020293”相匹配的价格&库存,您可以联系我们找货
