103030278
103030278
    SEEED(矽递科技)
    HIGH ACCURACY PI RTC (DS3231)
103030278 数据手册
            High Accuracy Pi RTC (DS3231)  SKU 103030278    The High Accuracy Pi RTC is based on the clock chip DS3231, the DS3231 is a low‐cost,  extremely accurate I2C realtime clock (RTC). It can provide a real‐time clock(RTC) for raspberry  pi via the I2C interface. With the clock source from the TCXO(temperaturecompensated crystal  oscillator), the RTC provides seconds, minutes, hours, day, date, month, and year information.  The date at the end of the month is automatically adjusted for months with fewer than 31 days,  including corrections for leap year.The clock operates in either the 24‐hour or 12‐hour format  with an AM/PM indicator.    The clock provides two programmable time‐of‐day alarms and a programmable square‐wave  output. The INT/SQW pin either generates an interrupt due to alarm condition or outputs a  square‐wave signal and the selection is controlled by the bit INTCN.    If you want to keep this module timing when the Raspberry Pi is powered off, you need to put a  3‐Volt CR1225 lithium cell in the battery‐holder.        Feature          Support Raspberry Pi 2/ 3 B/B+ Zero  Suport seconds,minuutes,hours,day of week,month, year  Support 24‐hour or 12‐hour format with AM/PM indicator  Low‐Power Consumption  Two Time‐of‐Day Alarms  Fast (400kHz) I2C Interface    Typical Applications     Any applications need Real Time on Raspberry.    Pin Out        Technical Details    Dimensions 25mm x 25mm x 15mm  Weight  G.W 13.90g      Battery  Exclude    Part List  High Accuracy Pi RTC (DS3231) 1  2pin Header  1  ECCN/HTS  ECCN EAR99  HSCODE  8473309000            https://www.seeedstudio.com/High%20Accuracy%20Pi%20RTC%20(DS3231)‐p‐3214.html/12‐4‐18
103030278 价格&库存
很抱歉,暂时无法提供与“103030278”相匹配的价格&库存,您可以联系我们找货
