SKU 103030356
Seeed Studio XIAO Expansion Board is a
powerful functional expansion board
for Seeed Studio XIAO series of only half
Raspberry Pi 4 size. It enables building
prototypes and projects in an easy and
quick way. With its rich peripherals, you
could explore the infinite possibilities of
Seeed Studio XIAO series. Circuit python
is also well supported by this board.
https://youtu.be/WKOseQoXEh4
Key Features
Quick Prototyping: Easy debug and Reset with RESET button and SWD pin led out
to the male header. 0.96” OLED, enables visual data to display without PC serial
monitor.
Rich peripherals: OLED display, RTC, expandable memory space, passive buzzer,
user button, on board battery management chip… One board on hand to explore the
infinite possibilities of Seeed Studio XIAO series.
Mini Size: Compact and elegant with only half Raspberry Pi 4 size, perfect for tiny and
wearable projects.
No Soldering Needed: All pins are led out. Convenient plug-and-play Grove
connectors support multiple data protocols, including IIC, Uart, and Analog/Digital.
Circuit Python Supported: Well, supports circuit python. Mini SD card slot enables
memory space expansion, making it possible to allocate more libraries needed in
prototyping and project building.
Rich peripherals on board including:
OLED display: Visual data display without connecting to PC, which enables debug in a
more efficient way, and builds application such as a sensor hub, data monitor
system, .etc.
RESET button: No more jumper wire and short circuit, easy reset with just one click.
SWD debug: SWD pin led out as male pin header, making debugger connection and
firmware download much easier.
High precision RTC: High precision real-time clock with battery backup, enables
maintaining accurate time when the main power is turned off.
Expandable memory: With a MicroSD card slot on the back, no worry about the
memory limit anymore when adding libraries and using circuit python.
User button: Besides the RESET button, also provide another user-defined button.
Passive buzzer: Same passive buzzer on Wio Terminal, with which you could change
the PMW frequency to award different beep sound to get a "buzzer music".
Grove connectors: All pin led out, plug-and-play grove connectors support common
data protocols (Grove IIC2, Grove UART1, A0/D0 Grove*1)
Lipo Battery Charging: JST2.0mm standard lipo battery connector and battery
management system, supports both USB and lipo battery power supply, and easy
onboard battery recharge.
5V servo connector: 5V output led out to male header for 5V servo and sensor
connection.
Seeed Studio SAMD21 XIAO has become one of the hottest products in the Seeeduino series
since its release. You may adore its small size and elegant design, powerful CPU powered by
SAMD21, or rich interfaces of GPIOs, but no matter what reason makes Seeed Studio XIAO
attract to you, now you have one more reason now - Seeed Studio XIAO Expansion Board,
which will help you to explore infinite possibilities with Seeed Studio XIAO Series.
Seeed Studio XIAO expansion board supports Seeed Studio XIAO SAMD21, Seeed Studio
XIAO RP2040, Seeed Studio XIAO nRF52840, Seeed Studio XIAO nRF52840 Sense.
Application
SMD debug
Rapid prototyping
Data display
Mini Size Project
https://www.seeedstudio.com/Seeeduino-XIAO-Expansion-board-p4746.html?queryID=bd1aef586d96a08ad9a2e813c1931aa7&objectID=4746&indexName=bazaar_retailer_
products 12/27/2022
很抱歉,暂时无法提供与“103030356”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+131.438061+17.08653
