103100062
103100062
    SEEED(矽递科技)
    Grove 转 Particle Mesh 连接性 Particle Mesh 平台评估扩展板
103100062 数据手册
      Grove Shield for Particle Mesh SKU 103100062    The Grove Shield for Particle Mesh is a Particle Mesh breakout in the form of Grove connector. Now you can use hundreds of Grove modules with Particle Mesh. Forget about breadboard and soldering iron, work with Grove requires no soldering and minimal wiring. Just plug the sensors, actuators, or displays into this shield via the Grove cable, then you can focus on coding and creation. There are 8 Grove connectors on this shield, including:     3 Grove analog connectors, 2 analog pins each, 6 analog pins in total 2 Grove digital connectors, 2 digital pins each, 4 digital pins in total; 2 Grove I2C connectors 1 Grove UART connector This tiny shield will combine the Particle Mesh with the whole Grove System and unleash your imagination.. Features    8 Grove connectors 3.3V compatible Easy to use Hardware Overview Figure 1. hardware overview                         https://www.seeedstudio.com/Grove‐Shield‐for‐Particle‐Mesh‐p‐4080.html/7‐17‐19
103100062 价格&库存
很抱歉,暂时无法提供与“103100062”相匹配的价格&库存,您可以联系我们找货
