103100163
103100163
    SEEED(矽递科技)
    BCM2711 载板 接口 Raspberry Pi 平台评估扩展板
103100163 数据手册
Ochin Tiny Carrier Board for Raspberry Pi Compute Module 4 SKU 103100163 The Ochin CM4 is a tiny carrier board for the Raspberry Pi Compute Module equipped with the powerful Quad-core Cortex-A72 CPU and GPU, which features a big RAM size, the CODECs, and Graphic Accelerators. It's designed for a wide range of applications such as robotics, home automation, and IoT projects. Features  High-performance: Broadcom BCM2711, Quad core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz  High Resolution Supported: H.265 (HEVC) (up to 4Kp60 decode), H.264 (up to 1080p60 decode, 1080p30 encode) and OpenGL ES 3.0 graphics  Rich interfaces: 1×USB 2.0 port (highspeed);MIPI CSI-2: 1×2-lane MIPI CSI camera port, 1×4-lane MIPI CSI camera port; 1×USART, 3×UART, 1×I2C port, 1×SPI port, Analog Video Output  Strong Compatibility: Compatible with raspberry pi 4 modules with faster eMMC flash with up to 100 MB/s transfer rate, 4x faster than CM3+  Compact Design: Same size as CM4 module, 55mm × 40mm × 4.7mm Specifications Processor:  Broadcom BCM2711, Quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz Resolution:  H.265 (HEVC) (up to 4Kp60 decode), H.264 (up to 1080p60 decode, 1080p30 encode)  OpenGL ES 3.0 graphics Interface:  1×USB 2.0 port (highspeed)  MIPI CSI-2: o 1×2-lane MIPI CSI camera port, 1×4-lane MIPI CSI camera port  1×USART, 3×UART, 1×I2C port, 1×SPI port, Analog Video Output Dimensions:  55mm × 40mm × 4.7mm Applications  Audio/video manipulation and streaming  Neural networks  Machine learning  Computer vision  Robotics  Drones  Home automation  IoT projects https://www.seeedstudio.com/Ochin-Tiny-Carrier-Board-for-Raspberry-Pi-Compute-Module-4-p5463.html?queryID=734d3824f7eb1b8df9e210eb5d5cdbb8&objectID=5463&indexName=bazaar_retailer_products 1-9-2023
103100163 价格&库存
很抱歉,暂时无法提供与“103100163”相匹配的价格&库存,您可以联系我们找货
  • 1+550.628611+71.44361
库存:73
