103990425
103990425
    SEEED(矽递科技)
    ROBO PI HAT MM1
103990425 数据手册
        Robo Pi HAT MM1 SKU 103990425  The Robotics Masters Robo HAT MM1 is an open source robotics controller board for Raspberry Pi. Note: Robo HAT MM1 will available from Seeed in around the end of Apr., the price will be released in Mar. It removes the initial barriers to starting any robotics project by providing all the hardware you need in one easy form factor. The wide compatibility with many open source software libraries such as CircuitPython, SeeSaw, and Arduino IDE gives you many options for getting your project to work.The hardware schematics and software will be fully available and open source without limitations. Features & Specification Raspberry Pi Compatibility (all models with 40‐pin header): Model B+, 2B, 2B+, 3B, and 3B+ Model A+ and 3A+ Zero and Zero W Dimensions: Standard HAT Format (width x depth): 65 mm x 56.5 mm height: TBC Sensors: Accelerometer, Gyroscope, Magnetometer in IMU (MPU‐9250) Current Sensor (INA219) Additional space for more sensors in the future (pressure sensor, duel IMU) Processor: 48 MHz SAM D21G 256 KB Internal Flash 8 MiB SPI External Flash Storage Connectivity: 24 programmable Input/Output: ‐ 9 x General I/O, 8 x 16‐bit Servo Output (programmable up to 24‐bit) ‐ 6 x direct to Raspberry Pi (SW programming, Control, Serial Console) ‐ 4 x 16‐bit RC Controller Input, NEOPIXEL Output JST DroneCode Complaint Connectors: ‐ GPS, UART, SPI, I2C USB to serial pass‐through to communicate with Raspberry Pi ‘in the field’ Power: on‐board 5V Regulator (for Raspberry Pi, Servos) on‐board small LiPo Battery Charger (for Raspberry Pi) battery pass‐through (for Servo, ESC, Raspberry Pi) independent servo power rail (for back‐powering from ESC) Software Compatibility    We wanted a wide range of software libraries to work on the Robo HAT MM1 to enable anyone to build the project that they want. This has the added benefit that the Robo HAT MM1 is able to work in a wide range of use‐cases. Supported CircuitPython (running on the device) SeeSaw (with CircuitPython on Raspberry Pi) Arduino IDE In Research / Development We beleive that these libraries can be added on in the future for expanding the number of projects that you can do. We plan on starting work on these libraries in the near future.    Scratch Environment (in development) PX4 (DroneCode) Flight Control (researching) ArduPilot Control (researching) Use Cases    Autonomous vehicles ‐ Donkey Car, DIY Robocar, ArduPilot and more. Educators ‐ easy to use for school aged students (testing underway). Makers and Hackers ‐ anyone looking to have fun or create something new with robotics. ECCN/HTS ECCN  ERA99  HSCODE                                     https://www.seeedstudio.com/Robo‐Pi‐HAT‐MM1‐p‐2915.html/4‐24‐19
103990425 价格&库存
很抱歉,暂时无法提供与“103990425”相匹配的价格&库存,您可以联系我们找货
