104020108
104020108
    SEEED(矽递科技)
    可寻址照明 - 30 LED 带 串行 红色,绿色,蓝色(RGB) 1000.00mm 长
104020108 数据手册
      Grove ‐ WS2813 RGB LED Strip Waterproof ‐ 30 LED/m ‐ 1m SKU 104020108 Several kinds of LED Strips have already been available in our bazaar for a long time, however, there were no Grove compatible LED strips. Now, we recommend the Grove ‐ WS2813 RGB LED Strip Waterproof series for you.    This series products are awesome, and have three significant advantages over other products: Grove Compatible ‐ you can just plug your LED Strip to Seeedunio or Arduino+BaseShild via Grove Cable, no soldering, no complicated wiring. WS2813 ‐ WS2813 is an upgraded version of WS2812, which is much more stable and stronger than WS2812: 1‐ support Resume from broken point; 2‐ all electronic components are integrated into the lamp beads Waterproof ‐ we add a transparent waterproof slot for those LED Strips According to the number of LEDs per meter, we have three models in this series. We have three models for this series of products: Grove ‐ WS2813 RGB LED Strip Waterproof ‐ 30 LED/m ‐ 1m Grove ‐ WS2813 RGB LED Strip Waterproof ‐ 60 LED/m ‐ 1m Grove ‐ WS2813 RGB LED Strip Waterproof ‐ 144 LED/m ‐ 1m We hope you enjoy it, just use those LED Strips to decorate your house, color your devices, and light up your way in darkness. Features      Grove Compatible Resume from broken point, even if there were broken LEDs, the rest LEDs can work well. WS2813B IC, 5050 LED Waterproof, IP65 Full color RGB, 16777216 colors, 256 levels of brightness The Resume from broken point Functions As long as not two or more adjacent LEDs are broken, the remaining LEDs will be able to work normally Technical Details Dimensions 1000mm x 12mm x 4mm  Weight  G.W 41g      Battery  Exclude  Operating Voltage  DC 5V  Operating Current  1.8A per meter / 0.06A per LED  Operating Temperature  ‐40  ~ 70   Storage Temperature  ‐50  ~ 80   Max. Power  9W per meter / 0.3W per LED  Scanning Frequency  2KHz/s  Max. Data Transfer Rate  800Kbps/s  Reset Time  >280us (typical = 300us)  LED Working Life‐Span  50000 Hours  Part List Grove ‐ WS2813 RGB LED Strip  Waterproof ‐ 30 LED/m ‐ 1m 1  ECCN/HTS ECCN EAR99  HSCODE  9405409000                  https://www.seeedstudio.com/Grove%20‐%20WS2813%20RGB%20LED%20Strip%20Waterproof%20‐%2030%20LED/m%20‐%201m‐p‐3124.html 9‐7‐18
104020108 价格&库存
很抱歉,暂时无法提供与“104020108”相匹配的价格&库存,您可以联系我们找货
  • 1+57.292711+7.42623
库存:142
104020108
  • 1+53.46464
库存:143
