104020048
104020048
    SEEED(矽递科技)
    P9813S14 LED RGB 可链接 Opto Grove 平台评估扩展板
104020048 数据手册
      Grove – Chainable RGB Led V2.0 SKU 104020048   Description RGB LED always bring us vivid and magic light effect, especially when there are a large number of LEDs shining together. However it is not easy to connect all the LEDs together if you want to build such LED projects. Why not have a try with Seeed’s Grove- Chainable RGB LED V2.0. Grove-Chainable RGB LED V2.0 is based on P9813S14 chip. This chip is a full-color light source driver chip that can provide three constant current driver and 256 greyscale modulation output. The key word of this product is “Chainable”, so how many LEDs can it be chained? By connecting the output grove connector of one LED to the input grove connector of another one, you are able to chain 1024 RGB LEDs at most! If you have experience using Grove-Chainable RGB LED V1.0, you will find that V2.0 is a bit longer than V1.0. In V2.0, because we adjust the grove connectors to be parallel with the board instead of vertical, so that the cable don’t need to be crooked. Document Please visit our wiki page for more info about this product. It will be appreciated if you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum. Technical Details Dimensions 40mm x 20mm x 15mm Weight G.W 11g Battery Exclude Input voltage 5V Working temperature -40 – 85Ԩ Max working current 60mA Max Chained LED Quantity: 1024 256 greyscale modulation output Part List Grove – Chainable RGB Led V2.0 1 Grove Cable 1                         https://www.seeedstudio.com/Grove‐%E2%80%93‐Chainable‐RGB‐Led‐V2.0‐p‐2903.html 8‐30‐17
104020048 价格&库存
很抱歉,暂时无法提供与“104020048”相匹配的价格&库存,您可以联系我们找货
    • 1+49.71566
    库存:63
