Grove ‐ WS2813 RGB LED Strip Waterproof ‐
60 LED/m ‐ 1m
SKU 104020109
Several kinds of LED Strips have already been available in our bazaar for a long time,
however, there were no Grove compatible LED strips. Now, we recommend the Grove ‐
WS2813 RGB LED Strip Waterproof series for you.
This series products are awesome, and have three significant advantages over other
products:
Grove Compatible ‐ you can just plug your LED Strip to Seeedunio or Arduino+BaseShild via
Grove Cable, no soldering, no complicated wiring.
WS2813 ‐ WS2813 is an upgraded version of WS2812, which is much more stable and
stronger than WS2812:
1‐support Resume from broken point;
2‐all electronic components are integrated into the lamp beads
Waterproof ‐ we add a transparent waterproof slot for those LED Strips
According to the number of LEDs per meter, we have three models in this series. We have
three models for this series of products:
Grove ‐ WS2813 RGB LED Strip Waterproof ‐ 30 LED/m ‐ 1m
Grove ‐ WS2813 RGB LED Strip Waterproof ‐ 60 LED/m ‐ 1m
Grove ‐ WS2813 RGB LED Strip Waterproof ‐ 144 LED/m ‐ 1m
We hope you enjoy it, just use those LED Strips to decorate your house, color your devices,
and light up your way in darkness.
Features
Grove Compatible
Resume from broken point, even if there were broken LEDs, the rest LEDs can work well.
WS2813B IC, 5050 LED
Waterproof, IP65
Full color RGB, 16777216 colors, 256 levels of brightness
The Resume from broken point Functions
As long as not two or more adjacent LEDs are broken, the remaining LEDs will be able to
work normally.
Attention
The max. power of this LED strip is 18W, the max. current is 3.6A(All the led turn to white, level 255).
We recommend that you use an extra power supply to power this LED strip. For example the max.
current supplied by Arduino UNO vcc is 200mA which is not enough.
Technical Details
Dimensions
1000mm x 12mm x 4mm
Weight
G.W 44g
Battery
Exclude
Operating Voltage
DC 5V
Operating Current
3.6A per meter / 0.06A per LED
Operating Temperature
‐40 ~ 70
Storage Temperature
‐50 ~ 80
Max. Power
18W per meter / 0.3W per LED
Scanning Frequency
2KHz/s
Max. Data Transfer Rate
800Kbps/s
Reset Time
>280us (typical = 300us)
LED Working Life‐Span
50000 Hours
Part List
1
ECCN/HTS
ECCN
EAR99
HSCODE
9405409000
https://www.seeedstudio.com/Grove%20‐%20WS2813%20RGB%20LED%20Strip%20Waterproof%20‐%2060%20LED/m%20‐%201m‐p‐3126.html 9‐7‐18
很抱歉,暂时无法提供与“104020109”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+86.017801+11.14955
