104020128
104020128
    SEEED(矽递科技)
    GROVE - RGB LED RING (20 - WS281
104020128 数据手册
         Grove - RGB LED Ring (20 - WS2813 Mini) SKU 104020128   Grove ‐ RGB LED Ring (20 ‐ WS2813 Mini)  is a cost‐effective full color LED ring with 20 chainable and  programmable WS2813 mini LEDs.  The Grove ‐ RGB LED Ring (20 ‐ WS2813 Mini) is a mini version of WS2813 Digital RGB LED Ring. The RGB  LED Ring are 3535‐sized LEDs with an embedded microcontroller inside the LED. The WS2813s are each  addressable as the driver chip is located inside the LED. Each LED has a constrant current drive so the  color will be very consistent even if the change of the voltage.  Note We've Released the Grove Selection Guide and hope to help you find the Grove suit you best. Features      The control circuit and RGB chip are integrated in a 3535 components, to form an external  control pixel. Intelligent Reverse‐connection protection. Built‐in signal reshaping circuit 256 gray level and 16777216 full‐color display Dual‐signal wires version, signal break‐point continuous transmission Signal break-point continuous transmission   As long as not two or more adjacent LEDs are broken, the remaining LEDs will be able to work  normally. Typical Applications Guardrail tube series, point light display series, flexible/rigid strips series, module series  applications. Lighting stage costumes, innovative gadgets or any other electronic products. Pin Out Part List Grove ‐ RGB LED Ring (20  1  ‐ WS2813 Mini)  Grove Cable  1  ECCN/HTS ECCN  EAR99  HSCODE  9405409000  UPC          https://www.seeedstudio.com/Grove‐RGB‐LED‐Ring‐20‐WS2813‐Mini‐p‐3227.html/9‐17‐19
104020128 价格&库存
很抱歉,暂时无法提供与“104020128”相匹配的价格&库存,您可以联系我们找货
  • 1+71.13692
库存:21
