104020148
104020148
    SEEED(矽递科技)
    38MM 8*8 SQUARE MATRIX LED MATCH
104020148 数据手册
          38mm 8*8 square matrix LED matched with Grove ‐ Green Common  Anode SKU 104020148   LED Matrix is low cost and usually used to display simple numbers and images. This is a 38mm 8*8 square matrix LED which can be pluged in the Grove ‐ LED Matrix Driver (It' s the I2C based product which allows you to control the LED matrix with our prepared and easy‐to‐use libraries, or you can create your own library to control it to satisfy your need). The 8*8 LED Matrix can be assembled and unassembled from the driver board easily, so it is convenient to change different color LED matrix display based on your need. Specification ‐ Pixel Array: 8X8 ‐ Color: Green ‐ Luminous Intensity: 55mcd ‐ Dimension: 38mmX38mmX7mm ‐ Weight: 12g ‐ Reverse Voltage(Max): 5V ‐ Forward Current(Max): 20mA ‐ Peak Forward Current(Max): 150mA ‐ Operating Temperature(Max):‐40~+85 ‐ Storage Temperature(Max): ‐40~+100 ‐ Lead Solder Temperature(Max): 260 for 3 seconds ECCN/HTS ECCN  EAR99  HSCODE    https://www.seeedstudio.com/38mm‐8‐8‐square‐matrix‐LED‐matched‐with‐Grove‐Green‐Common‐Anode‐p‐4050.html/9‐13‐19
104020148 价格&库存
很抱歉,暂时无法提供与“104020148”相匹配的价格&库存,您可以联系我们找货
