38mm 8*8 square matrix LED matched with Grove‐ Red Common
Anode
SKU 104020149
LED Matrix is low cost and usually used to display simple numbers and images. This is a
38mm 8*8 square matrix LED which can be pluged in the Grove ‐ LED Matrix Driver (It' s
the I2C based product which allows you to control the LED matrix with our prepared and
easy‐to‐use libraries, or you can create your own library to control it to satisfy your need).
The 8*8 LED Matrix can be assembled and unassembled from the driver board easily, so it
is convenient to change different color LED matrix display based on your need.
Specification
‐ Pixel Array: 8X8
‐ Color: Red
‐ Luminous Intensity: 55mcd
‐ Dimension: 38mmX38mmX7mm
‐ Weight: 12g
‐ Reverse Voltage(Max): 5V
‐ Forward Current(Max): 20mA
‐ Peak Forward Current(Max): 150mA
‐ Operating Temperature(Max):‐40~+85
‐ Storage Temperature(Max): ‐40~+100
‐ Lead Solder Temperature(Max): 260 for 3 seconds
ECCN/HTS
ECCN
HSCODE
EAR99
https://www.seeedstudio.com/38mm‐8‐8‐square‐matrix‐LED‐matched‐with‐Grove‐Red‐Common‐Anode‐p‐4051.html/9‐12‐19
很抱歉,暂时无法提供与“104020149”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 32+8.7002232+1.13100
