104020169
104020169
    SEEED(矽递科技)
    WS2813 LED RGB Opto Grove 平台评估扩展板
104020169 数据手册
  Grove - RGB LED (WS2813 Mini) SKU 104020169   We have already released Grove RGB LED Ring and Grove RGB LED Stick. Here comes a new product called Grove ‐ RGB LED (WS2813 Mini). Grove ‐ RGB LED uses the same component WS2813 mini compared with Grove ‐ RGB LED ring. It can be programmed with full display colour and be used for connecting other RGB LED rings or RGB LED sticks by series mode. For example, if you want to build up a Olympic rings with LED, you can choose RGB LED rings for the Olympic rings and this RGB LED for the bridge to connect the Olympic rings together. Cause they are from the same type and they can be driven by the same power supplier. Besides, you can get a couple of LED to scrabble any pattern you like. So hope you get one and finish your amazing project! Features      256 gray levels, 256*256*256=16777216” full‐color display Built‐in control circuit in a 3535 components Chainable, can be cascaded with multiple LED rings Support 5V/3.3V power in, support 5V/3.3V control data level. Dual‐signal wires, signal break‐point continuous transmission Signal break‐point continuous transmission As long as not two or more adjacent LEDs are broken, the remaining LEDs will be able to work normally Hardware Overview ECCN/HTS HSCODE  UPC  9405409000      https://www.seeedstudio.com/Grove‐RGB‐LED‐WS2813‐Mini‐p‐4269.html/10‐3‐19
104020169 价格&库存
很抱歉,暂时无法提供与“104020169”相匹配的价格&库存,您可以联系我们找货
