104030047
104030047
    SEEED(矽递科技)
    STARTER SHIELD TICK TOCK V2
104030047 数据手册
    Starter Shield EN(Tick Tock shield) v2 SKU 104030047   This Starter Shield is a perfect choice for the beginners of Maker World. By playing with it, you can literally learn some basic skills that are required to be a maker, like soldering techniques, basic electronic circuit principles and programming skills. What? Afraid of soldering and programming? Don’t worry, we’ve prepared a very detailed Soldering Guide and fully supported library of programming examples from easy level to hard level, you can always find something useful in it.   Starter Shield contains most commonly used components like buttons, light sensors, temperature sensors, buzzer and display etc. Once you finish the soldering task, you’ll find out it’s actually a geek style alarm clock which can auto adjust the brightness of display and keep in synch with real world time. Yet, you have to connect it to an Arduino/Seeeduino board and download the code first.  Features      Soldering friendly through‐holes  Alarm clock in geek style  All‐in‐one platform for beginners  Arduino/Seeeduino compatible    Part List                            1x Buzzer 3V;  1x CAP Aluminum 100uF‐16V;  1x Temperature Sensor‐10k;  1x LS06‐S phototransistor  4x RES 10K‐5%‐1/4W;  4x RES 220R‐5%‐1/4W;  3x RES 4.7K‐5%‐1/4W;  2x Blue Male Header VERT;  2x Blue Male Header VERT;  1x Blue Female Header VERT;  1x Lithium‐ion Battery 3V‐40mAh;  1x SMD Battery Cell Holder Plastic;  1x IC Driver;  1x RTC Clock/Timing;  2x IC Socket;  3x Button Top;  2x Black Round Female Header VERT;  1x LED Green‐Green;  1x LED Blue‐Blue;  2x LED Red‐Red;  1x LED 7‐SEG‐Red;  1x Crystal 32.768KHz‐12.5pF‐20ppm‐30K;  2x CAP Ceramic Disc 1nF‐50V‐20%;  1x CAP Ceramic Disc 100nF‐25V;  1x Starter Shield Soldering Guide  1x Starter Shield PCB          Technical details  Dimensions  140mm x75mm x29mm  Weight  G.W 66.5g  Battery  Lithium Cells/Batteries packed with equipment UN3481 ‐PI966    Part List  Buzzer 3V  1  CAP Aluminum 100uF‐16V  1  Temperature Sensor‐10k  1  LS06‐S phototransistor  1  RES 10K‐5%‐1/4W  4  RES 220R‐5%‐1/4W  4  RES 4.7K‐5%‐1/4W  3  Blue Male Header VERT  2  Blue Male Header VERT  2  Blue Female Header VERT  1  Lithium‐ion Battery 3V‐40mAh  1  SMD Battery Cell Holder Plastic  1  IC Driver  1  RTC Clock/Timing  1  IC Socket  2  Button Top  3  Black Round Female Header VERT  2  LED Green‐Green  1  LED Blue‐Blue  1  LED Red‐Red  2  LED 7‐SEG‐Red  1  Crystal 32.768KHz‐12.5pF‐20ppm‐30K  1  CAP Ceramic Disc 1nF‐50V‐20%  2  CAP Ceramic Disc 100nF‐25V  1  Starter Shield Soldering Guide  1  Starter Shield PCB  1  ECCN/HTS        ECCN  EAR99  HSCODE  8531909000  ROHS  1                        https://www.seeedstudio.com/Starter‐Shield‐EN‐Tick‐Tock‐shield‐v2‐p‐2768.html2‐28‐19
104030047
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚集电极,6脚发射极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输入电流为10mA,输出电流为10mA。
5. 功能详解:EL817通过内部的发光二极管和光敏三极管实现电-光-电转换,实现信号隔离。
6. 应用信息:EL817广泛应用于数字通信、测量设备、工业控制系统等领域。
7. 封装信息:EL817采用DIP-6封装。
104030047 价格&库存
很抱歉,暂时无法提供与“104030047”相匹配的价格&库存,您可以联系我们找货
