Nextion Enhanced NX8048K070 - Generic 7.0'' HMI
Touch Display
SKU 104060029
Description
The Nextion Enhanced versions are more powerful than the standard ones. Compare to the
basic Nextion displays, the enhanced ones have added some new functions, such as:
supporting built-in RTC, supporting save data to Flash, supporting GPIO, larger flash
capacity and larger CPU clock. The enhanced Nextion series has 7 size covers from generic
2.4'' to 7.0''.
Nextion Enhanced NX8048K070 is a powerful 7.0'' HMI TFT display, with 32MB Flash data
storage space, 1024 byte EEPROM, 8192 byte RAM. With GPIO supported, now customers
can use Nextion to control external devices.
Nextion is a seamless Human Machine Interface (HMI) solution that provides a control and
visualization interface between a human and a process, machine, application or appliance.
Nextion is mainly applied to Internet of thing (IoT) or consumer electronics field. It is the
best solution to replace the traditional LCD and LED Nixie tube.
Nextion includes a hardware part (a series of TFT boards) and a software part (the Nextion
editor). The Nextion TFT board uses only one serial port to communicate. It lets users avoid
the hassle of wiring. We noticed that most engineers spend much time in application
development but get unsatisfactory results. As a solution to this situation, Nextion editor
has mass components such as button, text, progress bar, slider, instrument panel etc. to
enrich the interface design. Furthermore, the drag-and-drop function ensures that users
spend less time in programming, which will reduce 99% of their development workloads.
With the help of this WYSIWYG editor, designing a GUI is a piece of cake. It's easy to adapt
Nextion family HMI to existing projects- users just need to provide it a UART.
Note: there's a small power supply test board and a wire for you to test if the electricity
supply is enough or not. Please see below image on how to use it.
Features
Supports built-in RTC
Supports GPIO
SD Card interface: support max 32G Micro TF/SD card (FAT32 file format)
Flash data storage space: 32MB
EEPROM: 1024 bytes
RAM: 8192 bytes
Instruction buffer: 1024 bytes
Color: 65K (65536) colors
Resolution: 800×480 pixel
Adjustable Brightness: 0~230 nit- the interval of adjustment is 1%
Specification
Visual Area: 154.08mm(L)×85.92mm(W)
Layout size: 181(L)×108(W)×9.3(H)
Touch type: Resistive
Backlight: LED
Backlight lifetime (Average): >30,000 Hours
Net Weight: 268 g
Recommended power supply: 5V 2A
Certificates: CE/EMC, RoHS (certificates)
Technical support
For technical support, please open a ticket on Nextion Forum.
Technical Details
Dimensions
181mm x 108mm x 9.3mm
Weight
G.W 340g N.W 268g
Battery
Exclude
Discontinued
No
Link Wiki
No
Display Resolution
800 x 480
Display Interface
Serial
Screen Type
Touch Screen
Display Controller
No
TFT display interface
N/A
Display Size
7.0”
Board Size
181mm*108mm
Expand
SD Card Socket; Touch Screen
Part List
7.0"Nextion Enhanced HMI Display
1
1
4-pin grove cable
1
https://www.seeedstudio.com/Nextion-Enhanced-NX8048K070---Generic-7.0%27%27-HMI-Touch-Display-p-3041.html 4-12-18
很抱歉,暂时无法提供与“104060029”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 20+1793.0096320+232.26773
