7 inch 1024x600 Capacitive TouchScreen
SKU 104990343
Description
It is a fantastic 7 inch HDMI monitor with capacitive touch screen and driver free. It's been tested on
Raspberry Pi, beagle bone black, windows 10 and Mac book pro. And it works well on those platform
and it really plug and play, all you need to do is to adjust the resolution(on Raspberry Pi).
It supports 1024x600 resolution and you may find that the pictures are more bright when you are using
this display. The capacitive touch function give the user full control over any device. It's driver free for
your device due to built‐in EDID device information, it is very easy to let the equipment correctly
identified the touch screen. And the Capacitive USB touch screen can support functions of the right
mouse button and drag and drop, and also support multipoint touch, maximum 10 points.(only test in
windows 10)
For use with a Raspberry Pi we suggest editing config.txt to set the HDMI to the native 1024x600 in case
it doesn't detect the resolution properly.
The easiest way to edit the config.txt is to put the Pi TF card into an every day computer and edit
config.txt with any text editor and save.
And most valuable things is it has been extended with two USB HOST ports. So that you can hookup
more USB devices to your screen, for example, the USB dongle or the USB mouse or keyboard.
Raspberry Pi Configure
•How to setup resolution for the screen:
•You can modify /boot/config.txt file with vim.tiny or nano editor, and change the parameters as
following chart:
Resolution
config file
1024x600
hdmi_group=2
hdmi_mode=87
hdmi_cvt
1024
600
hdmi_force_hotplug=1
Please reboot Raspberry Pi after modifying the /boot/config.txt
60
3
Technical Details
Dimensions
210mm x 150mm x 50mm
Weight
G.W 350g N.W 230g
Battery
Exclude
Power
5V Power via USB Micro
Current
Max 500mA
Display Type
7 inch TFT LCD
Resolution
1024x600
Touchscreen
USB capacitive
Touch points
10 points maximum
Interface
HDMI & USB 2.0 Full Speed
Dimensions (without package)
177.06mm x 113.09mm x 15.2mm
Free‐driver
Free‐driver
Supports Raspbian, Ubuntu Mate, NOOBS with RaspberryPi
Supports Debian, Angstrom with BeagleBone
Supports Windows / Ubuntu / Mac with PC
Supports Intel‐Processor Base MiniPC
ULP (Ultra Low Power) consumption backlight
Extend Two USB HOST Ports
Part List
5 Inch Capacitive HDMI Display
1
30cm High Quality HDMI cable wire
1
MicroUSB Cable wire
1
https://www.seeedstudio.com/7‐inch‐1024x600‐Capacitive‐TouchScreen‐p‐2972.html 10‐19‐17
很抱歉,暂时无法提供与“104990343”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+990.069261+128.24860
