104990363
104990363
    SEEED(矽递科技)
    5 INCH CAPACITIVE TOUCH SCREEN &
104990363 数据手册
    5 inch Capacitive touch screen & Acrylic Case  Kit  SKU 104990363    Description  This package contains a 5 inch screen and a set of acrylic shell. This is a very beautiful display suite, you  can  make  it  as  your  second  monitor  computer  or  with  the  use  of  the  raspberry  pi. 5  inch  capacitive  screen is very powerful, it is driver freer and support multi touch even the maximum support 10 point  touch. It has a very good performance in the windows platform and for Linux and for Mac are also very  good. Even without the touch screen calibration, all you need to do is plug and play. Only need to adjust  the resolution in accordance with the actual needs when you are using Raspberry Pi.    Features  •Easy to assemble  •Driver free  •Multi point touch  •Capacitive touch screen  •Compatible with Linux/windows/Mac    Technical Details  Dimensions  210mm x 150mm x 50mm  Weight  G.W 350g      Battery  Exclude  Power  5V Power via USB Micro  Current  Max 500mA  Display Type  5 inch TFT LCD  Resolution  800x480  Touchscreen  USB capacitive  Touch points  10 points maximum  Interface  HDMI & USB 2.0 Full Speed    Part List  5 inch Capacitive Touch Screen  1  Acrylic Case Kit  1  30cm High Quality HDMI cable wire  1  MicroUSB Cable wire  1                        https://www.seeedstudio.com/5‐inch‐Capacitive‐touch‐screen‐%26‐Acrylic‐Case‐Kit‐p‐2969.html 10‐19‐17
104990363 价格&库存
很抱歉,暂时无法提供与“104990363”相匹配的价格&库存,您可以联系我们找货
