104990602
104990602
    SEEED(矽递科技)
    电阻 智能,智慧,发光二极管,图形 TFT - 彩色 TTL 2.4"(60.96mm) 320 x 240
104990602 数据手册
            Nextion Enhanced NX3224T024 ‐ Generic 2.4'' HMI 320*240 Touch  Display for Arduino Raspberry Pi SKU 104990602    Nextion is a Human Machine Interface(HMI) solution that provides a control and visualization interface  between a human and a process, machine, application, or appliance. Nextion is not just a touch display, it has  a hardware part and a software part which is well developed for HMI applications.  Key Features  Nextion TFT resistive touch display   2.4” with 320*240 resolution   Providing HMI function for external device like Arduino board or Raspberry Pi   Including GUI development software and many API commands for GUI development      Description  Nextion is a Human Machine Interface(HMI) solution that provides a control and visualization interface  between a human and a process, machine, application, or appliance. Nextion is not just a touch display, and it  has a hardware part and a software part which is well developed for HMI applications.   Nextion(NX3224T024) display is a TFT display with a resolution of 320*240. The touch panel for this display is  resistive touch. Nextion has only one serial(TTL) for power supply or connection with peripheral devices like  Arduino board or Raspberry Pi. What ‘s more? Nextion display has an MCU, and its frequency is up to 48MHz.  With the help of 4MB flash, 3584Byte RAM, and an SD card socket, this display is embedded with a rich  storage for HMI programming.   As for the software part, Nextion has rich resources. Nextion Editor is a Windows software for GUI  development. There are libraries for serial communication with Arduino boards and Raspberry Pi. Moreover,  a mass of API is defined for users in The Nextion Instruction Set. With these resources, I believe you will have  an easy experience with this display.                     Hardware Overview    Specification    Item Value Color 64K 65536 colors Resolution 320×240 pixel Touch-type Resistive Touches > 1 million Backlight LED Backlight lifetime (Average) >30,000 Hours Operating Voltage 5V Operating Current 90mA Normal Mode, 15mA Sleeping Mode   Power supply recommend 5V, 500mA, DC Serial Port Baudrate 2400(Min), 9600(Typical),115200(Max) Serial Port Mode TTL Serial Port 4Pin_2.54mm USB interface NO SD card socket Yes (FAT32 format), support maximum 32G Micro SD Card FLASH Memory 4 MB RAM Memory 3584 Byte   Dimension  2.4”_Nextion_Dimension  Part List   Nextion NX3224T024*1   Power Supply Test Board*1   XH2.54 4P Wire*1  Related Nextion Display            Type of NX3224T02 NX4024T03 NX4832T03 NX4827T04 NX8048P07 NX1060P10 Display 4 2 5 3 0-011R 1-011C-I Size 2.4" 3.2" 3.5" 4.3" 7.0" 10.1" 320*240 400*240 480*320 480*272 800*480 1024*600 RTP RTP RTP RTP RTP CTP Flash 4MB 4MB 16MB 16MB 128MB 128MB RAM 3584Byte 3584Byte 3584Byte 3584Byte 512KB 512KB MCU 48 MHz 48 MHz 48 MHz 48 MHz 200 MHz 200 MHz EEPROM - - - - 1024Byte 1024Byte GPIOS - - - - 8 8 RTC - - - - Yes Yes Resolutio n Touch panel Frequenc y             ECCN/HTS  HSCODE  UPC  9013803010          https://www.seeedstudio.com/Nextion‐Enhanced‐NX3224T024‐Generic‐2‐4‐HMI‐320‐240‐Touch‐Display‐for‐Arduino‐Raspberry‐Pi‐p‐4330.html/12‐9‐19
104990602 价格&库存
很抱歉,暂时无法提供与“104990602”相匹配的价格&库存,您可以联系我们找货
