104990605
104990605
    SEEED(矽递科技)
    电阻 智能,智慧,发光二极管,图形 TFT - 彩色 TTL 4.3"(109.22mm) 480 x 272
104990605 数据手册
Nextion Enhanced NX4827T043 - Generic 4.3'' HMI 480*272 Touch Display for Arduino Raspberry Pi SKU 104990605 Nextion is a Human Machine Interface(HMI) solution that provides a control and visualization interface between a human and a process, machine, application, or appliance. Nextion is not just a touch display, it has a hardware part and a software part which is well developed for HMI applications. Key Features • • • • Nextion TFT resistive touch display 4.3” with 480*272 resolution Providing HMI function for external device like Arduino board or Raspberry Pi Including GUI development software and many API commands for GUI development Description Nextion is a Human Machine Interface(HMI) solution that provides a control and visualization interface between a human and a process, machine, application, or appliance. Nextion is not just a touch display, and it has a hardware part and a software part which is well developed for HMI applications. Nextion(NX4827T043) display is a TFT display with a resolution of 480*272. The touch panel for this display is resistive touch. Nextion has only one serial(TTL) for power supply or connection with peripheral devices like Arduino board or Raspberry Pi. What ‘s more? Nextion display has an MCU, and its frequency is up to 48MHz. With the help of 16MB flash, 3584Byte RAM, and an SD card socket, this display is embedded with a rich storage for HMI programming. As for the software part, Nextion has rich resources. Nextion Editor is a Windows software for GUI development. There are libraries for serial communication with Arduino boards and Raspberry Pi. Moreover, a mass of API is defined for users in The Nextion Instruction Set. With these resources, I believe you will have an easy experience with this display. Hardware Overview Specification Item Value Color 64K 65536 colors Resolution 480*272 pixel Touch-type Resistive Touches > 1 million Backlight LED Backlight lifetime (Average) >30,000 Hours Operating Voltage 5V Operating Current 250mA Normal Mode, 15mA Sleeping Mode Power supply recommend 5V, 500mA, DC Serial Port Baudrate 2400(Min), 9600(Typical),115200(Max) Serial Port Mode TTL Serial Port 4Pin_2.54mm USB interface NO SD card socket Yes (FAT32 format), support maximum 32G Micro SD Card FLASH Memory 16 MB RAM Memory 3584 Byte Dimension 4.3”_Nextion_Dimension Part List • • • Nextion NX4827T043*1 Power Supply Test Board*1 XH2.54 4P Wire*1 Related Nextion Display Type of Display NX3224T024 NX4024T032 NX4832T035 NX4827T043 NX8048P070011R NX1060P101011C-I Size 2.4" 3.2" 3.5" 4.3" 7.0" 10.1" Resolution 320*240 400*240 480*320 480*272 800*480 1024*600 Touch panel RTP RTP RTP RTP RTP CTP Flash 4MB 4MB 16MB 16MB 128MB 128MB RAM 3584Byte 3584Byte 3584Byte 3584Byte 512KB 512KB MCU Frequency 48 MHz 48 MHz 48 MHz 48 MHz 200 MHz 200 MHz EEPROM - - - - 1024Byte 1024Byte GPIOS - - - - 8 8 RTC - - - - Yes Yes ECCN/HTS HSCODE UPC 9013803010 https://www.seeedstudio.com/Nextion-Enhanced-NX4827T043-Generic-4-3-HMI-480-272-Touch-Display-for-Arduino-Raspberry-Pi-p-4333.html/12-9-19
104990605 价格&库存
很抱歉,暂时无法提供与“104990605”相匹配的价格&库存,您可以联系我们找货
