104990606
104990606
    SEEED(矽递科技)
    电阻 智能,智慧,发光二极管,图形 TTL 7"(177.80mm) 800 x 480
104990606 数据手册
Nextion Intelligent NX8048P070-011R - Generic 7.0'' HMI 800*480 Touch Display for Arduino Raspberry Pi SKU 104990606 Nextion is a Human Machine Interface(HMI) solution that provides a control and visualization interface between a human and a process, machine, application, or appliance. Nextion is not just a touch display, it has a hardware part and a software part which is well developed for HMI applications. PRODUCT DETAILS Key Features • Nextion IPS resistive touch display • 7.0” with 800*480 resolution • Providing HMI function for external device like Arduino board or Raspberry Pi • Including GUI development software and many API commands for GUI development Description Nextion is a Human Machine Interface(HMI) solution that provides a control and visualization interface between a human and a process, machine, application, or appliance. Nextion is not just a touch display, and it has a hardware part and a software part which is well developed for HMI applications. Nextion(NX8048P070-011R) display is an IPS display with a resolution of 800*480. The touch panel for this display is resistive touch. Nextion has only one serial(TTL) for power supply or connection with peripheral devices like Arduino board or Raspberry Pi. What ‘s more? Nextion display has an MCU, and its frequency is up to 200MHz. With the help of 120MB flash, 512KB RAM,1024 Byte EEPROM, and an SD card socket, this display is embedded with a rich storage for HMI programming. Different from the other type"T" Nextion displays, this type"P" Nextion has 8 extra GPIOs(two of which are PWM pins) for connecting peripheral equipment. And there is an RTC module on the display for controlling these devices in realtime. As for the software part, Nextion has rich resources. Nextion Editor is a Windows software for GUI development. There are libraries for serial communication with Arduino boards and Raspberry Pi. Moreover, a mass of API is defined for users in The Nextion Instruction Set. With these resources, I believe you will have an easy experience with this display. https://youtu.be/FMWQ1dXZr2I Hardware Overview Specification Item Value Color 64K 65536 colors Resolution 800x480 pixel Touch-type Resistive Touches > 1 million Backlight LED Backlight lifetime (Average) >30,000 Hours Operating Voltage 5V Operating Current 430mA Normal Mode, 170mA Sleeping Mode Power supply recommend 5V, 1.0A, DC Serial Port Baudrate 2400(Min), 9600(Typical),921600(Max) Serial Port Mode TTL Serial Port 4Pin_2.54mm USB interface NO SD card socket Yes (FAT32 format), support maximum 32G Micro SD Card FLASH Memory 120 MB RAM Memory 512 KB EEPROM 1024 Byte Instruction Buffer 1024 Byte Extended IO RTC 8 Digital extended GPIO, IO0-IO7 support input, output, and component binding event, IO6-IO7 support PWM built-in RTC support (Battery type: CR1220) Dimension NX8048P070-011R_Dimension Part List • Nextion NX 8048P070-011R HMI Display*1 • XH2.54 4P wire*1 • power supply test board*1 Related Nextion Display Type of NX3224T0 NX4024T0 NX4832T0 NX4827T0 NX8048P0 NX1060P1 Display 24 32 35 43 70-011R 01-011C-I Size 2.4" 3.2" 3.5" 4.3" 7.0" 10.1" 320*240 400*240 480*320 480*272 800*480 1024*600 RTP RTP RTP RTP RTP CTP Flash 4MB 4MB 16MB 16MB 128MB 128MB RAM 3584Byte 3584Byte 3584Byte 3584Byte 512KB 512KB 48 MHz 48 MHz 48 MHz 48 MHz 200 MHz 200 MHz EEPROM - - - - 1024Byte 1024Byte GPIOS - - - - 8 8 RTC - - - - Yes Yes Price $ $ $ $ $ $ Resoluti on Touch panel MCU Frequen cy ECCN/HTS HSCODE 9013803010 UPC LEARN AND DOCUMENTS Documentations Software: Nextion Editor Libraries for Arduino or Raspberry Pi Editor Guide The Nextion Instruction Set Datasheet Nextion Intelligent NX8048P070-011R - Generic 7.0'' HMI 800*480 Touch Display for Arduino Raspberry Pi - Seeed Studio/11-30-20
104990606 价格&库存
很抱歉,暂时无法提供与“104990606”相匹配的价格&库存,您可以联系我们找货
  • 1+1057.533341+136.68535
