Grove ‐ I2C Mini Motor Driver
SKU 105020010
The Grove – Mini I2C motor driver is a very tiny motor driver with I2C interface, and it includes two
motor driver chips ‐ DRV8830, which helps you control two DC motors or winding of stepper motors on
a small board simultaneously.
With four solderable pads back of the board, you can change the I2C address of each motor driver easily.
Especially, with the onboard protection circuit, the max limitation current of each channel can be
adjusted from 0.2A to 1A, you can set a proper limitation current according to the load.
It can be used for battery‐powered toys, printers, and other low‐voltage or battery‐powered motion
control applications due to the features.
Also, Grove – Mini I2C motor driver is belong to Grove System, you can plug it onto the Base shield and
work with Arduino directly without any jumper wires.
Features:
Tiny driver board
Two motor driver channels
Working Voltage : 2.75v – 6.8v
Changeable max limitation current
Grove compatible
I2C interface
Easy to use
Technical Details
Dimensions
130mm x 90mm x 10.5mm
Weight
G.W 9g
Battery
Exclude
Board Dimension
40mm X 20mm X 9mm
Part List
Grove ‐ Mini I2C Motor Driver v1.0
1
https://www.seeedstudio.com/Grove%C2%A0‐%C2%A0I2C%C2%A0Mini%C2%A0Motor%C2%A0Driver‐p‐2508.html 6‐8‐18
很抱歉,暂时无法提供与“105020010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+113.79390100+14.49310
- 国内价格 香港价格
- 1+112.720061+14.61067
