105090003
    SEEED(矽递科技)
    MAKER DRIVE - MIX1508 H-BRIDGE M
105090003 数据手册
      MAKER DRIVE ‐ MIX1508 H‐Bridge Motor Driver SKU 105090003 MIX1508 H-Bridge Motor Driver is DC motor driver assembled by MIX1508 chip for Robotic car. Are you interested in the robot motor? Do you want to start a motor driver? Here is your chance! MIX1508 H-Bridge Motor Driver is a powerful motor driver for beginners because of its easy-testing model and simplicity of operation. This motor driver has a Mix1508 chip for CPU, which is different from other MOSFET driver. So it has a smaller size. There are two groups of test buttons(each group contains two buttons) to correspond with two separated channels. With these test buttons, you don’t have to connect with the controller to test the driver, which is very convenient. The module also provides 4V~5V output to support the controller. MIX1508 H-Bridge Motor Driver can be powered by two AA or AAA batteries or a single LiPo battery. (3~3.7V).What ‘s more? It can be compatible with many controllers, such as Arduino and raspberry pi. Let’s get started with the robot motor experience! Features          Dual channel, Bi-directional control motor driver Support motor voltage from 2.5V to 9.5VDC Maximum current up to 1.0A continuous and 1.5A peak (
105090003 价格&库存
很抱歉,暂时无法提供与“105090003”相匹配的价格&库存,您可以联系我们找货
  • 50+35.8729350+4.48267
