106990290
106990290
    SEEED(矽递科技)
    ETA9740 电池充电器 电源管理 评估板
106990290 数据手册
    Lipo Rider Plus (Charger/Booster) ‐ 5V/2.4A USB Type C SKU 106990290   The Lipo Rider Plus from Seeed is not only a Fast Charger but also a Strong PowerBoost, supports up to  5V/2A charging current, boost output integration, output up to 5V/2.4A, can also output 3.3V /250mA.   Slow, slow, snail. Fast, fast, flash. Welcome to the era of fast charging! 5V/2A Lipo Rider Plus will greatly increase the charging speed, just like flashing lightning. The Lipo Rider Plus from Seeed is not only a Fast Charger but also a Strong PowerBoost, supports up to 5V/2A charging current, boost output integration, output up to 5V/2.4A, can also output 3.3V /250mA. The 3.3V output is normally on, and the 5V output supports IO control or manual switch, which means you can use 3.3V to supply power for a microcontroller and use the I/O of this microcontroller to control the 5V output, totally programmable. Wow, can’t believe it’s less than $5! Simply put, the Lipo Rider Plus can charge the Lipo battery much faster, at the same time it can provide strong power for the slave device. Oops, forgot to introduce the difference between the Lipo rider and the traditional Lipo charger. Lipo Rider VS Lipo Charger As we know, the traditional Lipo Charger can charge the lithium battery. Well, usually they can only charge. But what can a Lipo Rider do? Charging the lithium battery Of course, Lipo Rider Plus can charge the Lipo battery, and it is very fast, 5V/2A, 10W charging power, what a flying experience. Use the battery to power the device Not only a charger but also a power supply and a booster. With the help of Lipo Rider Plus, you can input a 3.7V lipo battery, and output up to 5V/2.4A via the USB Type‐A port. With the on‐board switch, you can control the ON/OFF of USB port easily. Meanwhile, we provide the full function pin header, which can output 3.3V/250mA as well. Lipo Rider Plus VS Lipo Rider & Lipo Rider Pro You may find that we've already released the Lipo Rider V1.3 and Lipo Rider Pro, so, what's the difference between Seeed Lipo Rider? In short, both LiPo Rider Pro and Lipo Rider v1.3 have two JST2.0 Port, which allows you to use a solar panel to charge a lipo battery. However, the Lipo Rider Plus only has one JST2.0 port. Hence, it can not use a solar panel as the power source. The good news is that Lipo Rider Plus has become more compact, it is almost half the size of LiPo Rider Pro and Lipo Rider v1.3, you can easily mount it in any project. More importantly, its performance is much stronger than its two predecessors. All in all, if you need to work with solar panels, then LiPo Rider Pro and Lipo Rider v1.3 are right for you; if you want to experience fast charging, then Lipo Rider Plus will be your best choice. Features        Up to 5V / 2A charging current ‐ USB Type C Up to 5V / 2.4A output current ‐ USB Type A Provides 3.3V / 250mA output ‐ Pin Header Support for shutdown output (IO control/manual switch) Onboard charge status indicator LED + Onboard 4‐segment power indicator LED Ultra‐small 2.5cm*4.1cm Single‐layer layout easy mount. Hardware Overview ECCN/HTS ECCN  EAR99  HSCODE  9030339000  UPC                  https://www.seeedstudio.com/Lipo‐Rider‐Plus‐p‐4204.html/9‐16‐19
106990290 价格&库存
很抱歉,暂时无法提供与“106990290”相匹配的价格&库存,您可以联系我们找货
