Grove ‐ Doppler Radar (BGT24LTR11) ‐ 24GHz Transceiver
SKU 109020021
The Grove – Doppler Radar is based on the BGT24LTR11 Silicon Germanium MMIC which is a 24GHz
radar transceiver. It is driven by an XMC1302 MCU based on Arm® Cortex®-M0. This comes in a
compact package and runs on very low power, providing high-precision measurements.
Features
The first radar-based sensor in the Grove Family
Compact size for easy deployment
Light-weight design, suitable for UAV applications
Low power consumption for prolonged usage
24GHz Transceiver MMIC for high-precision measurements
Fast response using electromagnetic waves
ESD protection to avoid system failures caused by ESD strikes
High penetration which allows it to be deployed behind an object
Maintains operation through harsh weather conditions (temperature, light, dust, rain)
Description
How would you build a system that could calculate the distance towards an object or detect
whether there is motion present?
Normally you would use an Ultrasonic or LiDAR Sensor for distance measurement and PIR
Motion Sensor for motion detection.
What if we told you there is an all-in-one module that could do all these functions more
precisely and also perform functions such as velocity detection of moving objects and angle
detection of objects. Would you believe it?
We were tired of using these traditional modules for motion-sensing applications and
wanted to deliver you a better solution, integrating new technologies.
Well…For the first time in the history of Grove, we are very excited to bring you a Grove
Module based on Radar Technology!
This is the Grove – Doppler Radar.
a 24GHz radar transceiver. It is driven by an XMC1302 MCU based on Arm® Cortex®-M0.
This comes in a compact package and runs on very low power, providing high-precision
measurements.
The high frequency of this module allows for high penetration though objects and therefore
this module does not need to be exposed outside when deploying, but rather behind an
object. This, in turn, is extremely useful in security systems. Also, this is able to operate in
harsh weather conditions such as high temperatures, dust, and rain.
You can watch the Seeed Weekly Show video below to learn more about this product and
other interesting products as well.
How Does Doppler Radar Technology Work in This Module?
Doppler radar works by sending a beam of electromagnetic radiation waves from the
transmitter (TX Antenna), with a precise frequency, at a moving object.
Once the electromagnetic radiation wave comes in contact with an object, it travels back
towards the receiver (RX Antenna). However, when the wave got reflected from the moving
object, the wave now has a different frequency compared to the original frequency, it
emitted.
Then the change in this frequency can be used to calculate the velocity of the moving object.
More Possibilities for Advanced Users
The Grove – Doppler Radar module is designed so that the pinouts are broken out from the
MCU and the MMIC to enable advanced users to tinker with this module.
Also, the onboard LED indicators can help users to identify whether the objects are moving
towards or away from the module. When the object moves towards the radar, it indicates
"NEAR" and when the object moves away from the radar, it shows "AWAY".
All in all, we believe that the Grove – Doppler Radar will open you to a whole new world of
possibilities!
Specifications
MMIC
BGT24LTR11
MCU
XMC1302 Arm® Cortex®-M0
Transmission Frequency
Min: 24GHz
Typical: 21.125GHz
Max: 24.25GHz
Output Power (EIRP)
7dBm @ 25°C
Update Time
300ms
Communication Interface
UART (115200)
Detection Distance
10m @ 0dBsm
Standard Detection Field
65° / horizontal (-6dB)
22° / vertical (-6dB)
Supply Voltage
3.3-5V
Weight
5g
Applications
Smart Home
Smart Building
Automatic Door
Lighting Control
Industrial Robotics
Intruder Alarm Systems
UAV
Hardware Overview
Dimensions
This product came into life with the joint efforts between Seeed Studio, Infineon
Technologies, and Honmax Technology.
Infineon Technologies: www.infineon.com
Honmax Technology: www.honmax.com.cn
Parts List
1 x Grove - Doppler Radar
1 x Grove Cable
ECCN/HTS
HSCODE
8529905000
UPC
https://www.seeedstudio.com/Grove‐Doppler‐Radar‐BGT24LTR11‐p‐4572.html/5‐12‐20
很抱歉,暂时无法提供与“109020021”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+580.478991+75.24113
