109020022
109020022
    SEEED(矽递科技)
    Air530 GPS RF Grove 平台评估扩展板
109020022 数据手册
    Grove ‐ GPS (Air530) SKU 109020022 Grove-GPS (Air530) is a high-performance, highly integrated multi-mode satellite positioning and navigation module, supporting plenty of location systems, such as GPS/Beidou/Galileo and etc. PRODUCT DETAILS Feature  Cost-effective  Highly integrated Multi-mode satellite positioning and navigation  Compact size for easy deployment  Low power consumption Description Confused about your GPS not working well in urban or outsides under only one or a few satellite module? Then you should not miss our new Grove-GPS (Air530). It’s a highperformance, highly integrated multi-mode satellite positioning and navigation module. It supports GPS / Beidou / Glonass / Galileo / QZSS / SBAS, which makes it suitable for GNSS positioning applications such as car navigation, smart wear and drone. Specification Parameters Values Supply voltage 3.3V/5V Working current up to 60mA Interface UART Time of warm start 4s Time of cold boot 30s Part list Items Values GPS (Air 530) board 1 Grove cable 1   Applications  GPS tracker  GPS navigation  Distance measurement   Pinout Cautions  The input power supply voltage of Grove power supply interface, should not exceed 5.6V, otherwise it may damage the device.  The voltage of the selected button battery should not exceed 3V, or it will probably damage the device. What is Grove? Grove makes it easier to connect, experiment, and simplify the prototyping process. No jumpers or soldering required. We have developed more than 300 Grove modules, covering a wide range of applications that can fulfil a variety of needs. Not only are these open hardware, but we also have open-source software. Note For all Grove users (especially beginners), we provide you with the guidance of operation. Please read the instructions through the official website before your using the product. ECCN/HTS HSCODE 8526919090 UPC                   https://www.seeedstudio.com/Grove‐GPS‐Air530‐p‐4584.html/5‐27‐20
109020022 价格&库存
很抱歉,暂时无法提供与“109020022”相匹配的价格&库存,您可以联系我们找货
  • 1+115.435261+14.93464
    库存:51
