110020052
110020052
    SEEED(矽递科技)
    WIO LINK DELUXE KIT W/GROVE MOD
110020052 数据手册
    Wio Link Deluxe Kit   SKU 110020052      This kit is a full package of lots frequently required functional modules for someone who intends to do some  real project or make a prototype. It contains sensors(mainly), switching‐function modules, servo motors, LED  strip and a speaker. The most amazing part of this kit is the Wio Link development board which can be  utilized for various devices: without a bit programming skill required. All the actions you want your modules  performed and the flashing‐code operation to Wio Link could be completed with taps in a mobile app. And  you can send instructions to your devices over the internet at anywhere. Wio Link will be a perfect utility to  make things around smarter for everyone. Now let us do something real!    Features  Full package of all general required functional modules  Grove port interfaced, more practical function and less work  Completely easy to make things around you smarter and add fun to daily life  Cost‐effective  Part List                     1x Grove ‐ Button  1x Grove ‐ Relay  1x Grove ‐ Moisture Sensor  1x Grove ‐ Temp&Humi Sensor  1x Grove ‐ Digital Light Sensor  1x Grove ‐ Rotary Angle Sensor  1x Grove ‐ Protoshield  1x Grove ‐ Magnetic Switch  1x Grove ‐ 3‐Axis Digital Accelerometer(1.5g)  1x Grove ‐ IR Distance Interrupt  1x Grove ‐ Barometer Sensor (BMP180)  1x Grove ‐ Air quality sensor v1.3  1x Grove ‐ Gesture  1x Grove ‐ I2C Hub  1x Grove ‐ Speaker  1x Grove ‐ WS2812 Waterproof LED Strip ‐ 30 LEDs 1 meter  1x Micro USB Cable ‐ 48cm  1x Grove ‐ Servo  2x Wio Link        Technical Details  Dimensions 200mm x 130mm x 70mm  Weight  G.W 363g      Battery  Exclude  Part List  Grove ‐ Button 1  Grove ‐ Relay  1  Grove ‐ Moisture Sensor  1  Grove ‐ Temp&Humi Sensor  1  Grove ‐ Digital Light Sensor  1  Grove ‐ Rotary Angle Sensor  1  Grove ‐ Protoshield  1  Grove ‐ Magnetic Switch  1  Grove ‐ 3‐Axis Digital Accelerometer(1.5g)  1  Grove ‐ IR Distance Interrupt  1  Grove ‐ Barometer Sensor (BMP180)  1  Grove ‐ Air quality sensor v1.3  1  Grove ‐ Gesture  1  Grove ‐ I2C Hub  1  Grove ‐ Speaker  1  Grove ‐ WS2812 Waterproof LED Strip ‐ 30 LEDs 1 meter  1  Micro USB Cable ‐ 48cm  1  Grove ‐ Servo  1  Wio Link  2  ECCN/HTS  ECCN 5A002.a.1  HSCODE  9023009000                                                            https://www.seeedstudio.com/Wio‐Link‐Deluxe‐Kit‐p‐2615.html/12‐5‐18
110020052 价格&库存
很抱歉,暂时无法提供与“110020052”相匹配的价格&库存,您可以联系我们找货
