110020053
    SEEED(矽递科技)
    WIO LINK DELUXE PLUS KIT W/GROVE
110020053 数据手册
  Wio Link Deluxe Plus Kit   SKU 110020053  DISCONTINUED  This item is no longer available.    This kit is same with Wio Link Deluxe Kit except this kit contain another two display modules,  which can add visual interfaces for your user. You can use this kit to run some real projects or do  prototyping. It contains sensors(mainly), switching‐function modules, servo motors, LED strip and  a speaker. The most amazing part of this kit is the Wio Link development board which can be  utilized for various devices: without a bit programming skill required.    All the actions you want your modules performed and the flashing‐code operation to Wio Link  could be completed with taps in a mobile app. And you can send instructions to your devices over  internet  at anywhere.  So  Wio  Link  will  be  a  perfect  utility to  make  things  around  smarter  for  everyone. Now let us do something real!  Features      Full package of all general required functional modules  Grove port interfaced, more practical function and less work  Completely easy to make things around you smarter and add fun to daily life  Cost‐effective    Part List                       1x  Grove ‐ Button  1x  Grove ‐ Relay  1x  Grove ‐ Moisture Sensor  1x  Grove ‐ Temp&Humi Sensor  1x  Grove ‐ Digital Light Sensor  1x  Grove ‐ Rotary Angle Sensor  1x  Grove ‐ Protoshield  1x  Grove ‐ Magnetic Switch  1x  Grove ‐ 3‐Axis Digital Accelerometer(±1.5g)  1x  Grove ‐ IR Distance Interrupt  1x  Grove ‐ Barometer Sensor (BMP180)  1x  Grove ‐ Air quality sensor v1.3  1x  Grove ‐ Gesture  1x  Grove ‐ I2C Hub  1x  Grove ‐ Speaker  1x  Grove ‐ WS2812 Waterproof LED Strip ‐ 30 LEDs 1 meter  1x  Micro USB Cable ‐ 48cm  1x  Grove ‐ Servo  1x  Grove ‐ OLED Display 0.96''  1x  Grove ‐ Ultrasonic Ranger  2x  Wio Link      Technical Details  Dimensions 200mm x 130mm x 75mm  Weight  G.W 393g      Battery  Exclude  Part List  Grove ‐ Button 1  Grove ‐ Relay  1  Grove ‐ Moisture Sensor  1  Grove ‐ Temp&Humi Sensor  1  Grove ‐ Digital Light Sensor  1  Grove ‐ Rotary Angle Sensor  1  Grove ‐ Protoshield  1  Grove ‐ Magnetic Switch  1  Grove ‐ 3‐Axis Digital  Accelerometer(±1.5g)  1  Grove ‐ IR Distance Interrupt  1  Grove ‐ Barometer Sensor (BMP180)  1  Grove ‐ Air quality sensor v1.3  1  Grove ‐ Gesture  1  Grove ‐ I2C Hub  1  Grove ‐ Speaker  1  Grove ‐ WS2812 Waterproof LED Strip ‐  30 LEDs 1 meter  1  Micro USB Cable ‐ 48cm  1  Grove ‐ Servo  1  Grove ‐ OLED Display 0.96''  1  Grove ‐ Ultrasonic Ranger  1  Wio Link  2  ECCN/HTS  ECCN 5A002.a.1  HSCODE  9023009000        https://www.seeedstudio.com/Wio‐Link‐Deluxe‐Plus‐Kit‐p‐2616.html/12‐5‐18
110020053 价格&库存
很抱歉,暂时无法提供与“110020053”相匹配的价格&库存,您可以联系我们找货
