110060462
110060462
    SEEED(矽递科技)
    GROVE IOT COMMERCIAL DEVELOPER
110060462 数据手册
Grove IoT Commercial Developer Kit SKU 110060462 DESCRIPTION The Grove IoT Commercial Developer Kit is produced by Seeed for Internet of Things (IoT) developers. The kit includes the Intel® NUC Kit DE3815TYKE, which is a pint-sized desktop computer that allows you to work, play, create, entertain and inspire in any room. Most importantly the Intel® NUC Kit has been pre-installed with an IoT Development System - a system that is designed by Intel to better helping the developers realize their IoT ideas. It has fully support to a bunch of well-chosen Grove modules, which are included in this developer kit and can be perfectly applied to the Arduino 101 IoT development board to build any IoT projects you want. NOTICE: This kit DOES NOT  include the Arduino 101. Intel® NUC Kit DE3815TYKE  This pint-sized package is a small device with big performance. It takes the capabilities of a complete desktop system and packs it all into a sleek 7.48" x 4.56" x 1.57" chassis. The kit features the Intel® Atom™ processor E3815 (512KB Cache, 1.46 GHz), which has a thermal design power (TDP) at only 5W so you won’t even feel the heat. It has an internal support for 2.5-inch HDD or SSD · Built-in 4 GB eMMC deive, while allows an expansion up to 8GB of 1333/1600 MHz DDR3L memory via SO-DIMM slot · Half-length mini PCIe* slot. More features of the kit can be found in the table below: Intel® NUC Kit DE3815TYKE Dimensions 7.48" x 4.56" x 1.57" Processor Intel® Atom™ processor E3815 (512KB Cache, 1.46 GHz Graphics Intel® HD Graphics (up to 400 MHz) Storage Internal support for 2.5-inch HDD or SSD · Built-in 4 GB eMMC device Expansion Up to 8 GB of 1333/1600 MHz DDR3L memory via SO-DIMM slot · Half-length mini PCIe* slot I/O USB 3.0 port · Five USB 2.0 ports (2 back, 3 internal) · HDMI* port · VGA port ·Embedded DisplayPort · Headphone/microphone jack · Intel® Gigabit LAN Suggested Use   Models Thin client · Digital signage · Attach to back of monitor (All-in-One) The Grove modules The kit provides an Arduino compatible Grove Base shield and a bunch of rich-featured Grove modules that covers a wide range of applications: The Grove - Piezo Vibration Sensor for motion detection, the Grove - Temperature Sensor_V1.1 for temperature measurement and the Grove - Sound Sensor_V1.2 for voice sensing etc. With the pre-installed IoT Development System in the Intel® NUC Kit DE3815TYKE, you can set up your IoT project and turn your idea into real thing easily and quickly. KEY FEATURES • Built-in IoT Development System in Intel® NUC Kit DE3815TYKE for Grove modules • Plug-N-play Grove system • Easy-to-use base shield for Arduino/Genuino 101 • Various well-chosen Grove sensors and actuators for rapid prototyping PART LIST 1x Intel® NUC Kit DE3815TYKE with 4G Memory Sensors: 1 x Grove- Button 1 x Grove – Sound Sensor v1.2 1 x Grove – Touch Sensor 1 x Grove – Light Sensor v1.2 1 x Grove – Temperature Sensor v1.1 1 x Grove – Rotary Angle Sensor(P) 1 x Grove – Piezo Vibration Sensor Actuators: 1 x Grove – LCD RGB Backlight 1 x Grove – Buzzer 1 x Grove – Red LED 1 x Grove – Green LED 1 x Grove – Blue LED 1 x Gear Stepper Motor with Driver Others: 1 x Grove Base Shield v2 14 x 26AWG Grove Cable 1 x B to A Type USB Cable – 0.5m Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved
110060462 价格&库存
很抱歉,暂时无法提供与“110060462”相匹配的价格&库存,您可以联系我们找货
