GrovePi Zero Base Kit
SKU 110060569
Description
The GrovePi Zero makes electronics prototyping with the Raspberry Pi Zero easy and fast. The
powerful little Raspberry Pi Zero is just waiting for you to release your maker creativity and
build the projects you’re passionate about. With the GrovePi Zero you can start your connected
device projects in minutes. This is a compact version of the GrovePi+! The kit allows you to
easily connect a variety of sensors to the Raspberry Pi. Simply connect a cable from the GrovePi
Zero to your sensor, download our software examples, and Raspberry Pi Zero enters the
physical world.
Note:
GrovePi Zero will NOT work with the original Raspberry Pi Model A & Raspberry Pi Model B.
Raspberry Pi Zero is not included in this kit.
Features
Connect multiple sensors to the raspberry pi zero.
Grovepi is a system that connects over 100 grove sensors and devices to the raspberry pi.
No need for soldering or breadboards: plug in your grove sensors and start programming.
Includes a sturdy case to protect your raspberry pi zero and grovepi zero.
The grovepi zero has 6 ports. There are 3 analog ports, 1 serial port, and 2 digital ports.
Part List
GrovePi Zero Board
1
GrovePi Zero Acrylic Case
1
Grove Sound Sensor
1
Grove Temperature and Humidity
1
Grove Light Sensors
1
Grove Relay
1
Grove Button
1
Grove Ultrasonic Ranger
1
Grove Rotary Angle Sensor
1
Grove LCD RGB Backlight
1
Grove Buzzer
1
Grove Red LED
1
Grove Blue LED
1
Grove Green LED
1
Technical Details
Dimensions
185mm x 125mm x 48mm
Weight
G.W 290g
Battery
Exclude
https://www.seeedstudio.com/GrovePi‐Zero‐Base‐Kit‐p‐3010.html 12‐12‐17
很抱歉,暂时无法提供与“110060569”相匹配的价格&库存,您可以联系我们找货
