110060623
110060623
    SEEED(矽递科技)
    LORA/LORAWAN GATEWAY - 915MHZ FO
110060623 数据手册
    LoRa/LoRaWAN Gateway - 915MHz for Raspberry Pi 3 SKU 110060623 Description LoRa is a perfect long-range wireless solution to create low-power, wide area networks.So far we have released several “LoRa” boards such as Seeeduino LoRaWan and Grove LoRa Radio etc. However if you want to build you own LoRa network, there are 3 things that you should prepare to get started: a Gateway, at least one Node and a local server where you can monitor all your devices. This kit provides a gateway & local server that allows you to collect and transfer data among all your LoRa nodes. By connecting the gateway with Seeeduino LoRaWAN and Grove modules, you can build your IOT prototype within minutes. Regarding the gateway module RHF0M301, it is a 10 channel(8 x Multi-SF + 1 x Standard LoRa + 1 x FSK) LoRaWan gateway moduel with a 24pin DIP port on board, users can easily connect the RHF0M301 with PRI 2 bridge RHF4T002, adapter for Raspberry Pi 3 and RHF0M301. There are several type of RHF0M301 distinguished by different communication frequency. This kit provides RHF0M301-915MHz, so we also included a 915MHz antenna. Apart from that the kit also contains an 8GB SD card and USB cables, Ethernet Cables and other accessories. Note:This kit does not contain Raspberry Pi 3 Board Features  Low power consumption & wide area  Industrial standard reliability  Economic solution to build LoRa /LoRaWAN network  Rich Accessories of sensor and actuator  Real time monitoring Part List  Gateway module RHF0M301 – 915 x 1  PRI 2 Bridge RHF4T002 x 1  8GB Micro SD Card – Class 10 x 1  USB to UART Adapter x 1  0dBi Rubber Duck Antenna x 1  Micro USB Cable 20cm x1  Micro USB Cable 100cm x 1  RJ45 Ethernet Cable 200cm x 1  5V/2.1A American Standard Adapter with Micro USB Connector x 1                            https://www.seeedstudio.com/LoRa%2FLoRaWAN‐Gateway‐‐‐915MHz‐for‐Raspberry‐Pi‐3‐p‐2821.html4/11/2017
110060623 价格&库存
很抱歉,暂时无法提供与“110060623”相匹配的价格&库存,您可以联系我们找货
