110060702
    SEEED(矽递科技)
    GROVE STARTER KIT FOR LINKIT 769
110060702 数据手册
      Grove Starter Kit for LinkIt 7697 SKU 110060702        Description  Grove starter kit for LinkIt 7697 is a complete hardware solution to help you explore the IoT space and create  innovative projects. It is a starter kit for LinkIt 7697, best choice for IoT developer to develop potential of LinkIt  7697 and build prototype.  The Grove Breakout board is specially designed for LinkIt 7697 to expand the connectivity to the larger amount  of Grove modules. Here are a collection of plug‐and‐ play Grove sensors, actuators and shields that we have had  success using with LinkIt 7697. Because the LinkIt 7697 can be plugged on breadboard directly, the kit also  contains some basic circuit components and a breadboard to let you getting started quickly.    Features  Support Arduino IDE  Grove Breakout for LinkIt 7697  Plug‐and‐play Grove modules   Part List  Grove Modules:   Grove Breakout for LinkIt 7697 x1   Grove ‐ IMU 9DOF x1   Grove – Temperature & Humidity Sensor Pro x1   Grove ‐ Ultrasonic Ranger x1   Grove ‐ Relay  x1   Grove ‐ OLED Display 0.96" x1   Grove ‐ Light Sensor x1   Grove ‐ LED Bar x1   Grove – Servo x1  Basic Circuit Components:   Breadboard 82mm x 53mm x1   Button x5   10K Ohm Rotary Potentiometer x1   1K Ohm Resistor x10   10K Ohm Resistor x10   330 Ohm Resistor  x10   RGB LED x1   Red LED x5  Others:   Micro USB Cable – 48 cm x1   Breadboard Jumper Wire x25   200g Kraft Paper Bag 115mm x 75mm  x1  Technical Details   Weight  G.W 329.5g      Battery  Exclude    Part List    Grove Breakout for LinkIt 7697  1  Grove ‐ IMU 9DOF  1  Grove – Temperature & Humidity Sensor Pro  1  Grove ‐ Ultrasonic Ranger  1  Grove ‐ Relay  1  Grove ‐ OLED Display 0.96"  1  Grove ‐ Light Sensor  1  Grove ‐ LED Bar  1  Grove – Servo  1  Breadboard 82mm x 53mm  1  Button  5  10K Ohm Rotary Potentiometer  1  1K Ohm Resistor  10  10K Ohm Resistor  10  330 Ohm Resistor  10  RGB LED  1  Red LED  5  Micro USB Cable – 48 cm  1  Breadboard Jumper Wire  25  200g Kraft Paper Bag 115mm x 75mm  1                                                        https://www.seeedstudio.com/Grove‐Starter‐Kit‐for‐LinkIt‐7697‐p‐2834.html 9‐8‐17
110060702 价格&库存
很抱歉,暂时无法提供与“110060702”相匹配的价格&库存,您可以联系我们找货
