110090161
110090161
    SEEED(矽递科技)
    HICAT LIVERA ROBOT KIT
110090161 数据手册
HICAT Livera Robot kit SKU 110090161 • • • Livera robot kit is an easy to build small size robot, by assembling and programming this robot you can develop a basic understanding of: Robot mechanical drive mechanics and dynamics. Coding for motors in dynamic situations. Machine vision for tracking objects and colors. • • • • • • • • • Features: 720hd video and photo capturing & openCV enabled image processing Image capturing and data recording onto the onboard SD card Mobile observation and manipulation from our custom apps (web-based and native) Visual enabled line follower, color sensing. Small size easy to build Pre-installed program with no software set up cost Low battery consumption Wi-Fi enabled wireless control Programmable and open source. Livera is a combination of Wi-Fi router, web cam, accelerometer, Arduino and Raspberry Pi, within a small board size. Image Capturing • • • • • Livera is a great platform for image capturing and processing. You can simply get images or videos by writing code, Arduino library with APIs within Arduino IDE Web API, there is a CGI server we have built on which APIs like photo and video capturing, video downloads, camera resolution setting etc. Cross compiles and run plain C program (adding node.js support) within Linux. Or using the custom Web or android app Using the native app or web app we've build for you by simply touch buttons. Line tracking This is an image capture and openCV line tracking app, we provide a C program which keep getting images (yuv format) from Livera, then using openCV api to detect the black line and draws down marks on the image, constantly updating and viewing the updated image through web interface. Part List HICAT Livera Board 1 Motor Driver Board 1 Camera Module 1 Livera Camera Extend Cable 1 2G SD Card with firmware built in 1 Hicat Livera Guidebook 1 Battery Case 1 E-MAX SERVO 1 DC Gear Motor set (Motor + Motor Carrier + Wheels) 2 Robot Base Acrylic Panel 1 Robot Top Acrylic Panel 1 Omni-directional Wheel Set 1 M2x15 (+6) mm Nylon Stud 4 M2x6mm Nylon Stud 4 M2x6 (+6) mm Nylon Stud 8 M2x10 (+6) mm Nylon Stud 8 M2 Nylon Nut 4 LASER Bean 1 Stickers 1 USB Cable 1 Screwdriver (+, -) 1 Technical Details Dimensions 193mm x 123mm x 80mm Weight G.W 360g Battery Exclude Documents • • How to build it. HiCAT Livera Document https://www.seeedstudio.com/HICAT-Livera-Robot-kit-p-3019.html 1-11-18
110090161
1. 物料型号:SKU 110090161 2. 器件简介:Livera机器人套件是一个易于构建的小型机器人,通过组装和编程,可以发展对机器人机械驱动力学和动力学、动态情况下的电机编码、机器视觉追踪物体和颜色的基本理解。 3. 引脚分配:文档中没有提供详细的引脚分配信息。 4. 参数特性: - 720HD视频和照片捕捉,支持OpenCV图像处理 - 图像捕捉和数据记录到板载SD卡 - 通过自定义应用程序进行移动观察和操作 - 视觉引导的线路跟踪器,颜色感应 - 小尺寸,易于构建 - 预装程序,无需软件设置成本 - 低电池消耗 - Wi-Fi无线控制 - 可编程且开源 5. 功能详解: - 图像捕捉:通过编写代码获取图像或视频 - 线路跟踪:使用OpenCV API检测黑线并绘制标记 6. 应用信息:Livera是一个结合了Wi-Fi路由器、网络摄像头、加速度计、Arduino和Raspberry Pi的小型板。 7. 封装信息:尺寸193mmx123mmx80mm,毛重360g,不含电池。
110090161 价格&库存
很抱歉,暂时无法提供与“110090161”相匹配的价格&库存,您可以联系我们找货
