110990947
110990947
    SEEED(矽递科技)
    CONVEYOR BELT KIT FOR DOBOT MAGI
110990947 数据手册
      Conveyor Belt Kit for Dobot Magician SKU 110990947      Description Simplest mini production line  The Conveyor Kit for Dobot Magician makes you have a complete production line simulation. Conveyor belt with  adjustable speed, distance and color sensor, combined with the powerful and programmable Dobot Magician,  these are the ideal essentials for you to create a highly effective simulated production line, or even to apply to  actual factory scenes.          Programmable switch and speed, stable running, this is our most ideal selection for you.    Accurately inspect object position, suitable for object recognition and distance check.    The accurate and responsive tool for you to effectively select and categorize objects.    These colorful wooden cubes are easy to grab, move and pile, the ideal material for you to get a grip of conveyor  controlling.  Technical Details   Dimensions  700mm x 215mm x 60mm  Weight  G.W 4.2g      Battery  Exclude  Payload  500g  E ective delivering distance  600 mm  Maximum speed  120 mm/s  Maximum acceleration  1100 mm/s²  Distance measuring   Measurable range  20 ~ 150 mm  sensor unit  Signal  Analog Output  Input  4.5 – 5.5 V  Color recognizing   Input  20 ~ 150 mm  snesor unit  Detectable  non‐glowing object  White LED embedded, on/o controllable    Part List    Conveyor Belt  1  Distance Sensor  1  Color Sensor  1  Wood Block  1    AddThis Sharing Buttons                                                       https://www.seeedstudio.com/Conveyor‐Belt‐Kit‐for‐Dobot‐Magician‐p‐2902.html 9‐8‐17
110990947 价格&库存
很抱歉,暂时无法提供与“110990947”相匹配的价格&库存,您可以联系我们找货
