110991330
110991330
    SEEED(矽递科技)
    BASIC ELECTRONICS KIT FOR FABLAB
110991330 数据手册
     Basic Electronics kit for FabLAB SKU 110991330    Part List General electronic components Quickie IDC Connectors 2X2P SNGL BM RCPL 30 microinch gold 20 Quickie IDC Connectors 2X3P SNGL BM RCPL 30 microinch gold 20 Quickie IDC Connectors 2X5P SNGL BM RCPL 30 microinch gold 20 CABLE 9 COND 300' MULTI RIBBON- 1 Bergstik Headers 2X2P UNSHRD HDR 30 microinch gold 20 Bergstik Headers 2X3P UNSHRD HDR 30 microinch gold 40 Bergstik Headers 2X5P UNSHRD HDR 30 microinch gold 20 ST M3 STM32F103 HEADER BOARD 2 IC MCU AVR 4K FLASH 20MHZ 14SOIC- 20 IC AVR MCU 4K 10MHZ 8SOIC- 20 IC MCU 8BIT 32KB FLASH 32TQFP 5 CER RESONATOR 20.00MHZ SMD 20 CER RESONATOR 16.00MHZ SMD 20 RESONATOR CER 8.00 MHZ W/CAP SMD 20 CRYSTAL 20.000000 MHZ 8PF SMD 20 RES 0.0 OHM 1-4W 5% 1206 SMD- 30 RES .10 OHM 1-4W 1% 1206 SMD 10 RES .25OHM 1W 1% 2010 SMD 10 RES 1.00 OHM 1-4W 1% 1206 SMD- 20 RES 4.99 OHM 1-4W 1% 1206 SMD 30 RES 10.0 OHM 1-4W 1% 1206 SMD 30 RES 49.9 OHM 1-4W 1% 1206 SMD- 30 RES 100 OHM 1-4W 1% 1206 SMD 30 RES 499 OHM 1-4W 1% 1206 SMD- 30 RES 1.00K OHM 1-4W 1% 1206 SMD- 30 RES 4.99K OHM 1-4W 1% 1206 SMD 30 RES 10.0K OHM 1-4W 1% 1206 SMD 30 RES 49.9K OHM 1-4W 1% 1206 SMD 30 RES 100K OHM 1-4W 1% 1206 SMD 30 RES 499K OHM 1-4W 1% 1206 SMD 30 RES 1.00M OHM 1-4W 1% 1206 SMD- 30 RES 4.99M OHM 1-4W 1% 1206 SMD- 30 RES 10.0M OHM 1-4W 1% 1206 SMD- 30 CAP CERAMIC 1PF 50V NP0 1206-$0.04200- 20 CAP CERAMIC 10PF 50V NP0 1206-$0.03612- 20 CAP CERAMIC 100PF 50V NP0 1206-$0.04200- 20 CAP 1000PF 1KV CERAMIC X7R 1206-$0.15300- 20 CAP 10000PF 50V CERAMIC X7R 1206 $0.03360- 20 CAP CERAMIC .1UF 250V X7R 1206- 20 CAP CER 1UF 50V X7R 10% 1206- 20 CAP CER 10UF 35V Y5V 1206- 10 CAPACITOR SUPER 10F 2.7V RADIAL- 10 DIODE SCHOTTKY 100V SGL SOD-123- 20 DIODE SCHOTTKY 1A 100V MINI-SMA- 20 DIODE ZENER 500MW 3.3V SOD123- 30 DIODE ZENER 4.7V 500MW SOD-123- 30 StarTech.com USB-to-RS232 Serial DB9 Adapter Cable ICUSB232 2 Electronics production RES 0.0 OHM 1-4W 5% 1206 SMD- 10 RES 100 OHM 1-4W 1% 1206 SMD 10 RES 499 OHM 1-4W 1% 1206 SMD- 10 RES 1.00K OHM 1-4W 1% 1206 SMD- 10 IC MCU AVR 4K FLASH 20MHZ 14SOIC- 5 CER RESONATOR 20.00MHZ SMD 5 CAP CERAMIC .1UF 250V X7R 1206- 5 CAP CER 18PF 50V NPO 1206 5 Bergstik Headers 2X3P UNSHRD HDR 30 microinch gold 5 DIODE ZENER 500MW 3.3V SOD123- 10 CONN RECEPT MINI USB2.0 5POS 5 Input devices PHOTOTRANSISTOR NPN SMD PLCC-2 5 MIC CONDENSER ELECT OMNI -42DB- 3 IC RF TXRX 433/868/915 16-TSSOP 3 THERMISTOR NTC 10K OHM 10% 1206- 3 TEMP SENSOR RTD 1.0K OHM 1206 3 IC SENSOR HALL EFFECT SOT23W 3 IC ACCELEROMETER 3AXIS 16QFN 3 SWITCH SLIDE SPDT 12V 100MA GW- 3 SWITCH TACT SMD W-GND 160GF 3 SENSOR,ULTRASONIC,40KHZ,TRAN1,REC1,112db/67db,2000pf/VARIOUS 40TR12B-R 2 TRANSDUCER,PIEZO,30VAC,75dB, LEADS,0.5-20Hz,SINGLE TONE 3 Output devices LED RED CLEAR 1206 SMD- 10 LED GREEN CLEAR 1206 SMD- 10 LED YELLOW ORANGE CLEAR 1206 SMD 10 LED BLUE CLEAR 1206 REV MT SMD 10 LED WHITE YELLOW 260MCD 1206 10 LED RGB DIFFUSED 4PLCC SMD 10 LED IR GAA1AS WATER CLEAR SMD 10 LCD MODULE 16x2 CHARACTER- 2 SPEAKER 16X35MM 8 OHMS .5WATT- 2 Ultra-Micro Digital Servo 1.7g/0.05sec/0.075kg 2 Analog Servo 10g/1.4kg/0.09s 2 Single Chip Digital Servo (5V) 10g/1.4kg/0.09s 2 Standard Analog Servo 38g/4.3kg/0.17s 2 Single Chip Digital Servo (6V) 16g/2.5kg/0.13s 2 Metal Gear Servo 2.5kg/12.5g/0.14sec 2 MOTOR,DC,12VDC,8600RPM,63mA, SHAFT:Dia.0.08 ,0.43 L,14.8TOR 2 MOTOR,DC,12-24V,22600RPM,1.4A 88.5G-CM,20.6W,SHFT 02.3X13mm 2 MOTOR,STEP,7VDC/350Ma, 7.5 STEP ANGLE,680 g-cm 2 MOTOR,DC,GEAR,12V,50/1,120RPM, 1100G-CM,74MA 2 MOTOR,STEPPER,BIPOLAR,4VDC/1A 3600 GR-CM,1.8 STEP ANGLE 2 TRANSDUCER,PIEZO,30VAC,75dB, LEADS,0.5-20Hz,SINGLE TONE 3 ECCN/HTS ECCN  ERA99  HSCODE  9023009000  UPC  https://www.seeedstudio.com/Basic‐Electronics‐kit‐for‐FabLAB‐p‐4217.html/9‐17‐19
110991330 价格&库存
很抱歉,暂时无法提供与“110991330”相匹配的价格&库存,您可以联系我们找货
