111100001
111100001
    SEEED(矽递科技)
    机电元件 继电器 Raspberry Pi 平台评估扩展板
111100001 数据手册
      DockerPi 4 Channel Relay SKU 111100001   DockerPi 4 Channel Relay is a member of the DockerPi Series,more commonly used in IOT applications. DockerPi 4 Channel Relay can relay AC/DC, instead of traditional switches, to achieve more ideas. DockerPi 4 Channel Relay can stack up to 4, and can be stacked with other DockerPi expansion board. If you need to run for a long time, we also recommend that you use our DockerPi Power expansion board to provide more power. Features:            DockerPi Series Programmable Control directly(without programming) Extend the GPIO Pins 4 Channel Relay 4 Alt I2C Addr Support Relay Status LEDs Support 3A 250V AC Support 3A 30V DC Can Stack with other Stack board Independent of the mainboard hardware (require I2C support) How to connect the electrical device Please pay attention to this mark on the board:    NC = Normal Close COM = Common NO = Normal Open Register Map Register Address Function Value 0x01  Relay 1  0(FULL OFF) ‐ 1/255(ON)  0x02  Relay 2  0(FULL OFF) ‐ 1/255(ON)  0x03  Relay 3  0(FULL OFF) ‐ 1/255(ON)  0x04  Relay 4  0(FULL OFF) ‐ 1/255(ON)  Device Address Map DIP switch status icon Device Address 0x10  0x11  0x12  0x13  Part List: 1 x Docker Pi 4 Channel Relay 1 x Instructions 4 x M2.5*12 + 6 Copper stick 4 x M2.5*6 Nut 4 x M2.5*6 Half-round head screw ECCN/HTS ECCN  ERA99  HSCODE  853890000 UPC          https://www.seeedstudio.com/DockerPi‐4‐Channel‐Relay‐p‐4096.html/7‐17‐19
111100001
物料型号:DockerPi 4 Channel Relay,SKU 111100001
器件简介:DockerPi 4 Channel Relay可以代替传统开关,实现交流/直流的继电器功能,以实现更多创意想法。
引脚分配:文档提供了寄存器映射表,描述了控制继电器的寄存器地址、功能和值。
参数特性:支持3A 250V交流或3A 30V直流,具有4个继电器通道,支持4个不同的I2C地址。
功能详解:该器件具有可编程性,可以直接控制,无需编程,可以扩展GPIO引脚。
应用信息:可以堆叠至4个,还可以与其他DockerPi扩展板堆叠。如果需要长时间运行,推荐使用DockerPi Power扩展板来提供更多电力。
封装信息:包含1个Docker Pi 4 Channel Relay,1份说明书,以及一些安装所需的螺丝和铜柱。
111100001 价格&库存
很抱歉,暂时无法提供与“111100001”相匹配的价格&库存,您可以联系我们找货
