I2C CAN-BUS Module Based on MCP2551 and MCP2515
SKU 113020111
The I2C CAN Bus Module uses I2C for communication. Default I2C Address
0x25 and Max I2C Speed of 400k.
The board is small and flexible, which makes it can be quickly used in any
system with an I2C interface.
The MCP2551 is a high-speed CAN transceiver, fault-tolerant device that
serves as the interface between a CAN protocol controller and the physical bus.
The MCP2551 provides differential transmit and receive capability for the CAN
protocol controller and is fully compatible with the ISO-11898 standard.
The MCP2515 is a second-generation stand-alone CAN controller. It is pin and
function compatible with the MCP2510 and includes upgraded features like
faster throughput, databyte filtering, and support for time-triggered protocols.
The I2C CAN Bus Module is based on the high-performance MCP2515 CAN
Bus controller and MCP2551 CAN Bus transceiver, providing a CAN Bus
communication rate of up to 1Mb/s.
In addition, there is an Atmega168PA microcontroller on the board, you can
also program it through a USB to Serial board, modify the firmware or write your
application directly.
There's Grove connects as well as Grove cable included in the kit, which allows
connecting the module to your Arduino easily.
Features
Cart to CAN-BUS communication
Up to 1Mb/s CAN Bus baud rate (default 500k)
Work with Arduino/BeagleBone board/Pi or any MCU that integrated with
I2C
TX and RX led indicator for CAN Bus
4pin Grove connector to plug and play
3.3 / 5V working voltage
Easy-to-use Arduino library
Small size: 20x40 mm
Application
CAN Bus Monitor
Car Hacking
Part List
I2C CAN Bus Module x1
HY2.0 4-Pin Cable x1
Screwdriver x1
https://www.seeedstudio.com/I2C-CAN-Bus-Modulep5054.html?queryID=07abca5becc78b7c15a7d3824a013f2b&objectID=5054&indexName=b
azaar_retailer_products 12-13-2022
很抱歉,暂时无法提供与“113020111”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+174.483501+22.68230
