113050000
113050000
    SEEED(矽递科技)
    DIP20
    WIFI BEE V2.0
113050000 数据手册
    Wifi Bee v2.0 SKU 113050000   Description Wifi Bee v2.0 is the update version of Wifi Bee v1.0. We replace transceiver module MRF24WB0MA which is SPI interface with RN‐171 used UART interface. Wifi Bee v2.0 module incorporates 802.11 b/g radio, 32 bit processor, TCP/IP stack, real‐time clock, crypto accelerator, power management unit and analog sensor interface. It can directly plug into the Bee sockets and use the UART port for communication. You can also use AT command for advanced configuration to meet your unique requirement. Specification        Compatible with any Bee socket Host interface: UART Transmit power: 0dBm to 12dBm Frequency:2402~2480 MHz Channal:0~13 Integrated TCP / IP protocol stack On‐board Multilayer Chip Antenna Technical Details Dimensions 90mm x 55mm x 12mm  Weight  G.W 6g      Battery  Exclude  Part List Wifi Bee v2.0 1  ECCN/HTS ECCN Not Available  HSCODE  8517709000                                     https://www.seeedstudio.com/Wifi‐Bee‐v2‐0‐p‐1637.html 10‐18‐18
113050000 价格&库存
很抱歉,暂时无法提供与“113050000”相匹配的价格&库存,您可以联系我们找货
