113110004
113110004
    SEEED(矽递科技)
    HIKEY 960 KIRIN 960 EVAL BRD
113110004 数据手册
      HiKey 960 Development Board SKU 113110004 Description The HiKey 960 is powered by the latest Kirin 960 SoC with four ARM® Cortex®-A73 CPUs (up to 2.3GHz) and four ARM Cortex-A53 CPUs (up to 1.8GHz) configured according to the big.LITTLE™ architecture. The HiKey 960 is powered by the latest Kirin 960 SoC with four ARM Cortex-A73 CPUs (up to 2.3GHz) and four ARM Cortex-A53 CPUs (up to 1.8GHz) configured according to the big.LITTLE architecture. The integrated Mali™-G71 MP8 GPU in the Kirin 960 SoC gives the HiKey 960 high performance image processing abilities. With 3GB LPDDR4 memory and 32GB UFS flash on board, the HiKey 960 can be used for most embedded applications. The HiKey 960 has updated the USB Type-A host from USB2.0 to USB3.0 compared to the original HiKey board. In order to enhance the expansion ability, the HiKey 960 includes a PCIE Gen2 on M.2 M Key connector to enable PCIE device connection. The HiKey 960 also includes an updated WiFi module supporting 2.4GHZ single band to 2.4- and 5.0GHz dual band with two antennas. Android support for the HiKey 960 will be enabled through Android Open Source Project (AOSP). Additional software suppor will be added through collaboration between Huawei, Linaro and the community. SoC Kirin 960 SoC CPU 4*Cortex A73 (up to 2.3GHz) + 4*Cortex A53 (up to 1.8GHz) Big.LILLTE CPU architecture GPU ARM Mali G71 MP8, up to 900MHz RAM 3GB LPDDR4 SDRAM @ 1866MHz PMU Hi6421GWCV530 Hi6422GWCV211 Hi6422GWCV212 Sizes 85mm x 55mm 32GB UFS flash storage Storage MicroSD card slot (SD3.0, SDR104, up to 2TB) PCIE PCIE Gen2 on M.2 M Key connector WiFi (2.4- and 5-GHz dual band with two antennas) Wireless Bluetooth 4.1 2 x USB 3.0 type A (host mode only) USB 1 x USB 2.0 type C OTG 1 x HDMI 1.4 (Type A - full, up to FHD 1080P) Display 1 x 4L-MIPI DSI (Supports up to 3840 * 2400 @ 60Hz dual MIPI DSI interface LCD screen) 4K @30fps H.265/H264 video hardware encoder Video H265\HEVC MP/High Tier, Main/High Tier, H.264 BP/MP/HP, MPEG 1/2/4, VC-1, VP6/8, RV8/9/10, DIVX, H265 up to 4K @60fps video hardware decoder HDMI output Audio 1 x Tensilica HiFi3.0 DSP audio subsystem 1 x WiFi activity LED(Yellow) Camera 1 x BT activity LED (Blue) 4 x User LEDs (Green) Button Power Source OS Support Power Button : Button Power on/off & Reset the system Recommend a 12V@2A adapter with a DC plug which has a 4.75mm outer diameter and 1.7mm center pin with standard center-positive (EIAJ-3 Compliant) AOSP/LINUX                                                        https://www.seeedstudio.com/HiKey‐960‐Development‐Board‐p‐2839.html  4/3/2017
113110004 价格&库存
很抱歉,暂时无法提供与“113110004”相匹配的价格&库存,您可以联系我们找货
