Wio Core
SKU 113990234
ESP8266 embedded (FCC, CE,
KCC, TELEC, LCIE and IC certified)
Wio Link and Wio Node
compatible Ebedded with TCP/IP
network stacks, 10‐bit ADC, and
HSPI/UART/PWM/I2C/I2S
interfaces Ultra‐compact size for
space‐sensitive situations
What is the most important thing
on a board? I bet the answer
must be the MCU module. MCU is
like the brain of a board, without
which the board is useless.
At the beginning of 2016, in order to simplify the process of IoT project, we launched Wio
Link on Kickstarter and it turned out a big success, right after that, we released a mini
version of Wio Link --- Wio Node. Since then more and more makers are interested in its
MCU module---ESP8266, which is one the most famous SoC in Seeed now.
Wait! Are we talking about Wio Core? Of course we are. ESP8266 is just a chip, and a chip
without auxiliary circuitry is a body without bones and skin, that is why Wio core comes to
this world. Wio core is a WiFi module with ESP8266 embedded. Basically, Wio Core can be
considered equivalent to ESP-WROOM-02 except that the original firmware is replaced
with firmware of Wio platform. That means hardware developed from Wio Core will be
totally compatible with Wio Link and Wio Node, even software of Wio platform is available
for Wio core.
As just mentioned Wio Core is developed from ESP-WROOM-02, it is also FCC, CE, KCC,
TELEC, LCIE and IC certified with the best FCC results for IoT modules. Considering the size
is only 18mm x 20mm, it can be easily integrated into space-limited device. With a
sophisticated power management system, Wio Core can operate in sleep mode, the result is
extremely low power consumption. All these good features make Wio Core one of the best
solutions for mobile device, wearable device and IoT application.
Features
ESP8266 embedded (FCC, CE, KCC, TELEC, LCIE and IC certified)
Wio Link and Wio Node compatible.
Ebedded with TCP/IP network stacks, 10-bit ADC, and HSPI/UART/PWM/I2C/I2S
interfaces.
Ultra-compact size for space-sensitive situations.
Specification
Certificates: FCC/CE/TELEC/RoHS
Wi-Fi protocols: 802.11 b/g/n
Frequency range: 2.4 GHz–2.5 GHz (2400M–2483.5M)
Operating voltage: 3.0–3.6V
Operating current Average: 80 mA
Operating temperature range: -40°C–125°C
Package size: 18mm(length) × 20mm(width) × 3mm(depth) (for normal silk-reading
orientation)
Flash memory size: 4Mbyte
Firmware: Wio Firmware with OTA capability
User interface: Cloud Server, Android/iOS App
Documents
For libraries and documents, please visit our Wiki page.
For technical discussion, please come to our Forum.
For projects that you would like to share with the community, please visit Recipe.
Technical details
Dimensions
50mm x80mm x4.5mm
Weight
G.W 3g
Battery
Exclude
Part List
Wio Core
1
ECCN/HTS
HSCODE
8517709000
USHSCODE
8517700000
UPC
841454118695
https://www.seeedstudio.com/Wio‐Core‐p‐2689.html/3‐2‐20
很抱歉,暂时无法提供与“113990816”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 650+57.01838650+7.39067
