113990496
113990496
    SEEED(矽递科技)
    LTE PI HAT CAT.1 LARAR211 EUROPE
113990496 数据手册
LTE Cat 1 Pi HAT (Europe) SKU 113990496 Description Seeed’s LTE CAT.1 Pi HAT is an open source cellular extension modem for Raspberry Pi, based on u-blox LARA-R2xx series. It compatible with Raspberry Pi 1 Model B+ and later versions. LTE CAT.1 Pi HAT is designed for LTE Category 1 networks and with 2G fallback(EU version only). Embedding common protocols, like TCP/UDP, HTTP. LTE CAT.1 Pi HAT support UART and USB interfaces. By UART, Raspberry Pi communicate with LTE CAT.1 Pi HAT via AT command without any special driver. It’s well suited for building prototyping rapidly. Features • • • • • • • • • Compatible with Raspberry Pi 1 Model B+ and later versions LTE CAT.1 and support 2G fallback(EU version only) UART and USB interface for communicate Support Grove I2C and Digital connector Protocols on cellular module Embed TCP/UDP stack Embed HTTP, FTP, SSL Dual stack IPV4/IPV6 3GPP TS 27.007 [8], TS 27.005 [9] standard AT command Applications • • • • • • • • IoT gateway Data logger Vending machine POS Smart home devices Robot Advertising Other scenario need cellular networks Technical Details Dimensions 65mm x 56mm x 18.5mm Weight G.W 54g N.W 23.4g Battery Exclude Part List LTE Cat 1 Pi HAT (Europe) 1 LTE Antenna 2 https://www.seeedstudio.com/LTE-Cat-1-Pi-HAT-%28Europe%29-p-3060.html 6-8-18
113990496 价格&库存
很抱歉,暂时无法提供与“113990496”相匹配的价格&库存,您可以联系我们找货
