113990976
113990976
    SEEED(矽递科技)
    模块
    WiFi RF 收发器模块 PCB 印制线,不含天线,I-PEX 底座安装
113990976 数据手册
EMW3090 Wi-Fi Module Built-in ARM Cortex-M4F Wi-Fi MCU Datasheet 2.4G Hz IEEE 802.11 b/g/n, ultra-high integration, rich peripherals Version:2.6 Date: 2020-10-19 NO.: DS0125EN Abstract ⚫ Input Voltage:3.0V~3.6V ⚫ Operating Temperature:-20℃ to +85℃ ⚫ Processor:ARM Cortex-M4 Processor Core MX1290 ▪ MX1290,up to 125MHz ▪ MX1290V2,up to 62.5MHz ▪ 40MHz clock input ▪ SWD/JTAG simulation debugger interface ⚫ Interface and Dimension ▪ ⚫ Memory Maintain pin compatibility with similar package modules ▪ 256K bytes SRAM ▪ 512K bytes ROM ▪ 512 bytes OTP memory area ▪ 2M bytes XIP flash ▪ RF Interface: PCB antenna, or IPEX connector antenna ▪ 18mm x 20mm, stamp hole or pin ⚫ Application Functions ⚫ Wi-Fi ▪ IEEE 802.11 b/g/n 1T1R 2.4GHz Single Frequency ▪ Built-in power amplifier (PA) with self-calibration ▪ Support 802.11e QoS enhancement (WMM) ▪ Support WPA/WPA2 PSK,Open/WEP/ ▪ Support AliOS and MXOS operating system ▪ Provide major cloud platforms access SDK ▪ Mass production firmware for typical applications ⚫ Typical applications: TKIP/CCMP ▪ smart home appliances ▪ Support WPA/WPA2 Enterprise ▪ smart electric equipment ▪ Support WPS,Wi-Fi Direct ▪ Industrial automation ▪ Support IEEE Power Save mode ▪ MX1290: support HT20/HT40, 150Mbps max. ▪ MX1290v2: support HT20, 72Mbps max. ▪ Ordering Code Ordering Code Notes EMW3090-P PCB antenna,MX1290 processor EMW3090-E IPEX antenna, MX1290 processor 11 x GPIO EMW3090V2-P PCB antenna,MX1290V2 processor ▪ 1 x SPI EMW3090V2-E IPEX antenna, MX1290V2 processor ▪ 2 x I2C,support 400K high speed mode ▪ 5 x PWM,up to 2MHz frequency ▪ 2 x UART,support hardware flow control ▪ 1 ADC channel ▪ Low-energy RTC ⚫ Rich Peripherals ▪ EMW3090V2-P-TR PCB antenna,MX1290V2 processor, Tape and Reel Copyright of Shanghai MXCHIP Information Technology Co., Ltd. EMW3090 Series Wireless Module Datasheet Order Code Example EMW 3 09 0 V2 -P -xxx Product Series EMW=IoT Wi-Fi Module Product Type 3=Welding type wireless module Typical target applications and features 09=IOT Application 9 Series Dimensions, enhancements 0=18mm x 20mm,2 x 9 pins 1.5 space, stamp hole Processor version [omit]= MX1290 V2= MX1290V2 RF Interface P=2.4GHz On-Board PCB Antenna E=2.4GHz External Antenna IPEX Connector Option TR = tape and reel(default package is tray For a list of all relevant features (such as packaging, minimum order quantity, etc.) and other information, please contact the nearest MXCHIP sales point and agent. Accessories Order Code Description MXKIT-Base Development board for all EMW3090 modules MXKIT-Core-3090 The development board core board for the EMW3090, used with MXKIT-Base FX-3090 EMW3090 production fixture with accompanying test board:MXKIT-Base, MXKITCore-3090 Copyright of Shanghai MXCHIP Information Technology Co., Ltd. EMW3090 Series Wireless Module Datasheet Version Update Instructions Date Version Update Contents 2018-06-10 1.0 Release 2018-08-23 1.1 Add description of IO port level status at module startup 2018-12-26 1.2 Fixed SRRC ID 2019-01-17 1.3 Add module reference design circuit, add antenna parameters 2019-05-09 1.4 Change the antenna test parameters and clear zone schematic after MP 2019-05-13 1.5 Add OTA test data, modify sensitivity max. 2020-03-06 2.0 Rewritten according to new MXCHIP standard 2020-03-10 2.1 Update general assembly dimension diagram and pin distribution diagram 2020-03-24 2.2 Modify the default function and operating mode selection of pins 2020-04-16 2.3 Modify package information 2020-09-03 2.4 Update label information 2020-09-09 2.5 Update of order code information 2020-10-19 2.6 Reference design circuit updated Copyright Notice Without permission, it is prohibited to use or copy all or any part of this manual, especially for trademarks, model naming, part numbers and drawings. Copyright of Shanghai MXCHIP Information Technology Co., Ltd. EMW3090 Series Wireless Module Datasheet Contents Introduction ........................................................................................................................................................................... 1 Pin Definition ......................................................................................................................................................................... 3 Pin Arrangement ...........................................................................................................................................................................................3 Pin Definition .................................................................................................................................................................................................3 Electrical Parameter .............................................................................................................................................................. 6 Absolute Maximum Parameters ..................................................................................................................................................................6 Operating Voltage and Current ...................................................................................................................................................................6 General I/O interface ....................................................................................................................................................................................7 Typical Application Power Consumption ...................................................................................................................................................7 Temperature ...................................................................................................................................................................................................8 ESD ..................................................................................................................................................................................................................8 RF Parameter ..................................................................................................................................................................................................9 Antenna Information .......................................................................................................................................................... 13 PCB antenna parameters and use ............................................................................................................................................................ 13 4.1.1. On-board PCB parameter........................................................................................................................................................................................................ 13 PCB Antenna Clearance ............................................................................................................................................................................. 14 External antenna parameters and use ..................................................................................................................................................... 14 4.3.1. SRRC Important statements ....................................................................................................................................................................................................... 16 Dimensions and Production Guidance ............................................................................................................................ 17 Assembly Dimension Diagram.................................................................................................................................................................. 17 Recommended Package Drawing ............................................................................................................................................................. 17 Reference Circuits ............................................................................................................................................................... 18 Power ........................................................................................................................................................................................................... 18 Module basic circuit ................................................................................................................................................................................... 18 UART ............................................................................................................................................................................................................ 18 Production Guidelines ........................................................................................................................................................ 20 Precautions.................................................................................................................................................................................................. 21 Secondary reflow temperature curve ...................................................................................................................................................... 21 Storage Condition ...................................................................................................................................................................................... 22 Label Information ................................................................................................................................................................ 23 Sales and Technical Support Information ....................................................................................................................... 24 Table Catalog Table 1 MX1290 and MX1290V2 difference Table ....................................................................................................... 2 Table 2 Pin Arrangement .................................................................................................................................................. 3 Table 3 operation mode ................................................................................................................................................... 4 Table 4 Absolute Maximum Parameter:Voltage ........................................................................................................ 6 Table 5 Operating parameters: rated voltage and current ......................................................................................... 6 Table 6 Operation parameter:Typical RF power consumption ................................................................................ 6 Table 7 DC current: digital I/O ......................................................................................................................................... 7 Table 8 Typical application power consumption .......................................................................................................... 8 Table 9 Temperature and humidity parameters ........................................................................................................... 8 Table 10 Electrostatic discharge parameters ................................................................................................................ 8 Table 11 RF Parameter ...................................................................................................................................................... 9 Table 12 RF Parameters in IEEE802.11b mode .............................................................................................................. 9 Table 13 RF Parameters in IEEE802.11g mode ............................................................................................................ 10 Table 14 RF Parameters in IEEE802.11n HT20 mode ................................................................................................. 11 Table 15 RF Parameters in IEEE802.11n HT40 mode ................................................................................................. 12 Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 1 EMW3090 Series Wireless Module Datasheet Table 16 On-board PCB parameter ............................................................................................................................... 13 Table 17 Typical furnace temperature settings .......................................................................................................... 21 Figure Catalog Figure 1 EMW3090 Hardware Block Diagram .............................................................................................................. 1 Figure 2 Pin Arrangement ................................................................................................................................................ 3 Figure 3 IO The power-on state interface ..................................................................................................................... 5 Figure 4 Antenna minimum clearance area (unit: mm) ............................................................................................ 14 Figure 5 Copper tube antenna size ............................................................................................................................... 15 Figure 6 Dimension drawing of external antenna connector .................................................................................. 16 Figure 7 Assembly Dimension Diagram(unit: mm, tolerance: ±0.1, outside tolerance±0.2) ) ................... 17 Figure 8 Package size (unit: mm) .................................................................................................................................. 17 Figure 9 Power reference circuit ................................................................................................................................... 18 Figure 10 module basic circuit connection ................................................................................................................. 18 Figure 11 USB to serial port reference circuit............................................................................................................. 19 Figure 12 UART 3.3V/5V conversion circuit ................................................................................................................ 19 Figure 13 Humidity Card ................................................................................................................................................ 20 Figure 14 Typical secondary reflux temperature profile .......................................................................................... 22 Figure 15 Storage Conditions Diagram........................................................................................................................ 22 Figure 16 Label diagram ................................................................................................................................................. 23 Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 2 EMW3090 Series Wireless Module Datasheet Introduction The EMW308x/EMW309x series modules are mainly used for IoT data communication. Data collection and control are realized through a rich peripheral interface, and data can be transmitted to the Internet of Things cloud service platform through a Wi-Fi network connection to realize the Internet of Everything. This series of modules is used in a wide range of IoT applications through a variety of different form factors, interface types, antenna interfaces and temperature range. The module includes a super-integrated Wi-Fi microcontroller MX1290 that integrates a Cortex-M4F core up to 125MHz, 256K bytes of SRAM, 2M bytes of Flash memory, and IEEE 802.11 b/g/ n Standard 2.4 GHz RF. Streamlined peripheral circuitry makes the overall module size and interface design more flexible and easier to control costs. The high-performance processing core and security module greatly improve the speed of networking interaction and reduce the overall power consumption while ensuring data security. Shanghai MXCHIP provides MXOS and AliOS software platforms to support the development of EMW3090 series modules, providing an efficient development environment, access protocol stacks for various IoT cloud services, rich sample programs and various typical applications. The following figure shows the hardware block diagram of the EMW3090 module, which mainly includes: ⚫ Wi-Fi processor MX1290/MX1290V2 ⚫ Equipped with 2M bytes of SPI interface Flash memory ⚫ On-board or external antenna ⚫ Power and communication interface Figure 1 EMW3090 Hardware Block Diagram MX1290 Wi-Fi microcontrollers are provided in two versions, MX1290 and MX1290V2. In MX1290V2, in order to provide a more cost-effective choice for this series of modules, the software restricts hardware Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 1 EMW3090 Series Wireless Module Datasheet functions and cannot be lifted through software upgrades. The main differences are as follows: Table 1 MX1290 and MX1290V2 difference Table Model Main Frequency MX1290 125MHz MX1290V2 62.5MHz Wi-Fi Support HT20 and HT40,transmitting rate up to 150Mbps Support HT20,transmitting rate up to 72.2Mbps Copyright of Shanghai MXCHIP Information Technology Co., Ltd. Security Support Flash encryption,Trust Zone Lite - 2 EMW3090 Series Wireless Module Datasheet Pin Definition Pin Arrangement Figure 2 Pin Arrangement Pin Definition Table 2 Pin Arrangement Pin Main Function Name Number (After Reset) PWM UART I2C SPI Others 1 VDD 2 CHIP_EN(3) (5) 3 PA_0 PA_0 PWM_2 4 PA_12 PA_12 PWM_3 5 PA_19 PA_19 TIM5_TRIG UART0_CTS I2C0_SDA SPI1_CS ADC1 6 PA_22 PA_22 PWM_5 UART0_RTS I2C0_SCL SPI1_MISO WAKEUP_2 7 PA_30(1) (2) (5) UART2_Log_TX PWM_3 UART2_Log_TX I2C0_SDA PA_30 8 PA_29(2) (5) UART2_Log_RX PWM_4 UART2_Log_RX I2C0_SCL PA_29 9 VSS 10 PA_5 PA_5 PWM_4 11 PA_18 PA_18 TIM4_TRIG UART0_RX I2C1_SCL SPI1_CLK WAKEUP_0 12 PA_23 PA_23 PWM_0 UART0_TX I2C1_SDA SPI1_MOSI WAKEUP_3 13 VSS 14 PA_8(1) 15 NC 16 NC 17 PA_11(1) 18 VSS T1 PA_15 SWDIO PWM_1 T2 PA_14 SWCLK PWM_0 WAKEUP_1 PA_8 PA_11 Notes: 1. Module working mode selection signal. During the startup phase, the module detects the Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 3 EMW3090 Series Wireless Module Datasheet level of these pins and enters a specific working state. The correspondence between level and working mode is shown in Table 3: Table 3 operation mode PA_30 Operation mode (UART2_Log_TX) Default: 1 PA_11(BOOT) PA_8(EASYLINK) Default: 1 Default: 1 ISP Program Mode 0 not detect not detect Bootloader 1 0 1 ATE 1 0 0 Normal 1 1 (Default) not detect (1). During the startup phase, if the processor hardware detects that the PA_30 level is low, it enters the ISP programming mode. In ISP programming mode, you can program the flash of the module through UART2 (PA_29, PA_30). In normal use, the level of the PA_30 pin must be high or floating at the time of power-up, please pay special attention when designing the circuit. (2). After the startup is completed, when the processor runs the firmware provided by MXCHIP, the firmware detects the status of PA_11 and PA_8 to enter the corresponding working mode. 2. The UART2_Log serial port is used for the input / output of debugging information. Do not use it during design, and provide it in a convenient way to facilitate software development. 3. The CHIP_EN pin is an enable reset pin, which is active low and can be left floating if not used. Or pull up 3.3V. 4. Please keep unused pins floating. It should be noted that the IO port is in a floating state at startup. If you need to configure the state of the pin through software, you need to wait until the code in the bootloader starts to execute. The time from when the module is powered on to when the code in the bootloader is executed will be affected by the flash startup time. Therefore, if you need IO to be in a certain level state at startup, you need to use a 100k resistor on the pin to pull up and down. Figure 3 shows the level change of the IO port whose software is configured as a low level after being pulled up by an external 100K resistor in the floating state. It can be seen that the time from powering on the module to the IO port software controllable time is 69.4ms, Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 4 EMW3090 Series Wireless Module Datasheet during which the time for IO to be pulled to high level is about 20ms. Figure 3 IO The power-on state interface 5. The module has 100K hardware pull-up resistors in PA_30 (UART2_Log_TX) and PA_29 (UART2_Log_RX). The PA_0 pin has a 100K hardware pull-down resistor, and CHIP_EN has an internal 100K pull-up resistor and 0.01F capacitance to ground. Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 5 EMW3090 Series Wireless Module Datasheet Electrical Parameter Absolute Maximum Parameters Operation of the module outside of its absolute maximum ratings may result in permanent damage. At the same time, long-term exposure to the maximum rated conditions will affect the reliability of the module. Table 4 Absolute Maximum Parameter:Voltage Symbol Ratings Min Max Unit VDD–VSS Voltage –0.3 3.6 V VIN Input voltage on any other pin VSS−0.3 VDD+0.3 V Operating Voltage and Current Table 5 Operating parameters: rated voltage and current Symbol Note VDD VDD_IO IVDD Specification Min. Typical Max. Unit Voltage 3.0 3.3 3.6 V Digital IO Supply Voltage 1.62 1.8~3.3 3.6 V 450 mA 50 mA 3.3V Rating Current (with 450 mA internal regulator and integrated CMOS PA) IDD_IO IO Rating Current (including VDD_IO) IVDD Deep Sleep Mode 7 7 uA IVDD Deep Standby Mode 70 70 uA IVDD Sleep Power Gate 120 120 uA IVDD Sleep Clock Gate 350 350 uA Table 6 Operation parameter:Typical RF power consumption Symbol IVDD IVDD Note Specification CPU Wi-Fi Deep Sleep Mode Wi-Fi OFF Deep Standby Mode Pull up Flash CS pin Min. Typical Max. Unit 7 10 uA 150 uA 500 600 uA 14 26 mA Wi-Fi OFF IVDD Sleep Wi-Fi OFF IVDD Active Wi-Fi OFF IVDD Sleep Wi-Fi Associate, DTIM = 1 2.78 mA IVDD Sleep Wi-Fi Associate, DTIM = 3 1.49 mA IVDD Active Wi-Fi Associate, DTIM = 1 47 mA IVDD Active Wi-Fi Associate, DTIM = 3 46 mA IVDD Sleep Wi-Fi RX 90 mA IVDD Active Wi-Fi RX 120 mA IVDD Active TX@MCS7/HT40,13dBm 220 mA IVDD Active TX@MCS7/HT40,16.5dBm 230 mA 14 Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 6 EMW3090 Series Wireless Module Datasheet Symbol Note Specification CPU Wi-Fi Min. Typical Max. Unit IVDD Active TX@MCS7/HT20,13dBm 244 mA IVDD Active TX@MCS7/HT20,16.5dBm 257 mA IVDD Active TX@OFDM54M, 15dBm 255 mA IVDD Active TX@OFDM54M, 17.5dBm 267 mA IVDD Active TX@CCK11M, 17dBm 287 mA IVDD Active TX@CCK11M, 18dBm 295 mA IVDD Active RX@Idle, HT40 120 mA IVDD Active RX@MCS7, HT40 (Pin= -60dBm) 130 mA IVDD Active RX@MCS7, HT20 (Pin= -60dBm) 127 mA IVDD Active RX@OFDM54M (Pin= -60dBm) 127 mA IVDD Active RX@CCK11M (Pin= -60dBm) 115 mA IVDD Active RF Standby 84 mA IVDD Active RF disable 62 mA (1). The above parameters are measured in the laboratory wireless shielding environment. Refer to Table 8 for actual application power consumption. (2). In Deep Standby Mode, the CS signal of Flash should be pulled high, otherwise the MX1290 will generate leakage current on the Flash interface. (3). Flash power consumption is not included in the data in Table 6. When reading code or reading and writing data from the Flash, the power consumption of the Flash is not higher than 20mA, and the power consumption of the Flash in standby mode (CS signal pulled high) is not higher than 50A. General I/O interface Table 7 DC current: digital I/O Symbol Note Conditions VIH Input-High Voltage VIL Specification Min. Typical Max. Unit LVTTL 2.0 - - V Input-Low Voltage LVTTL - - 0.8 V VOH Output-High Voltage LVTTL 2.4 - - V VOL Output-Low Voltage LVTTL - - 0.4 V IT+ Schmitt-trigger High Level 1.78 1.87 1.97 V IT- Schmitt-trigger Low Level 1.36 1.45 1.56 V IIL Input-Leakage Current -10 1 10 A VIN=3.3V or 0 Typical Application Power Consumption The module current test environment is based on VDD=3.3V. Test under common office application environment (values measured under different test environments will be different). Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 7 EMW3090 Series Wireless Module Datasheet Table 8 Typical application power consumption Mode EMW3090 EMW3090V2 Unit Note 21 mA CPU idle 3.5 3.5 mA 24.7 19 20 mA 114. 121 110 126 mA 114 147 109 124 mA 14 290 9.06 282 mA SoftAP mode 118 306 116 306 mA SoftAP networking status Monitor mode 114 122 114 126 mA Distribution process, in RX state 10 12 10 12 A off, can be woken up by wake-up Average Max. Average Max. 28.3 28.3 21 3.5 3.5 24.6 Wi-Fi off Wi-Fi off Wi-Fi off Wi-Fi initial Keep Wi-Fi connected Keep Wi-Fi connected CPU idle, turn on low power consumption CPU running at full load Power on state, turn off low power consumption Turn off Wi-Fi and MCU low power consumption Turn on Wi-Fi and MCU low power consumption MCU / RAM / peripheral / RTC is Deepsleep mode pin or internal Timer Iperf Turn off Wi-Fi and MCU low performance 160 336 115 345 mA power consumption mode Iperf Turn on Wi-Fi and MCU low performance 164 332 115 353 mA power consumption mode Temperature Table 9 Temperature and humidity parameters ESD Symbol Ratings Max Unit TSTG Storage temperature –55 to +125 ℃ Twork Ambient Operating Temperature -20 to +85 ℃ TJun Junction Temperature 0 to +125 ℃ k Table 10 Electrostatic discharge parameters Symbol Name Name Electrostatic discharge VESD(HBM) voltage (Human body model) Level Max. 2 2000 TA= +25 °C comply with JESD22-A114 V Electrostatic discharge VESD(CDM) voltage (Discharge Unit TA = +25 °C comply with JESD22-C101 II 500 equipment model) Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 8 EMW3090 Series Wireless Module Datasheet RF Parameter Table 11 RF Parameter Item Specification Operating Frequency 2.412~2.484GHz Channel BW 20MHz,40MHz(MX1290 only) Antenna Interface 1T1R, Single stream Wi-Fi Standard IEEE 802.11b/g/n 11b: DBPSK, DQPSK, CCK for DSSS Modulation Type 11g: BPSK, QPSK, 16QAM, 64QAM for OFDM 11n: MCS0~7, OFDM 802.11b: 1, 2, 5.5 and 11Mbps 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbps Data Rates 802.11n: MCS0~7, up to 72.2Mbps 802.11n: MCS0~7, up to 150Mbps (MX1290 only) One U.F.L connector for external antenna Antenna type PCB printed ANT (Reserve) Note: The typical values of the following Tx test data are recorded under normal temperature environment and Tx lasts about 20s. IEEE 802.11b mode Table 12 RF Parameters in IEEE802.11b mode Item Description Mode IEEE802.11b Channel CH1 to CH13 Data rate 1, 2, 5.5, 11Mbps TX Characteristics Min. Typical Max. Unit 11b Target Power@1Mbps 15 16.5 18 dBm 11b Target Power@11Mbps 15.0 16.5 18.0 dBm fc +/-11MHz to +/-22MHz - - -30 dBr fc > +/-22MHz - - -50 dBr -15 -1 +15 ppm - -15.5 Min. Typical Max. Unit 1Mbps (FER≦8%) - -98 -97 dBm 11Mbps (FER≦8%) - -90 -90 dBm Transmitter Output Power Spectrum Mask Frequency Error Constellation Error (peak EVM) 1~11Mbps RX Characteristics 35%(or -11dB) Minimum Input Level Sensitivity Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 9 EMW3090 Series Wireless Module Datasheet The 11b power is the power obtained from the factory mode test (through the wall mode), the actual user application and certification test will be 2dB lower than the factory mode, i.e. the actual maximum power of the 11b is capped at 16dBm. ensure that the PSD test item of the certification test can be passed. IEEE802.11g mode Table 13 RF Parameters in IEEE802.11g mode Item Description Mode IEEE802.11g Channel CH1 to CH13 Datarate 6, 9, 12, 18, 24, 36, 48, 54Mbps TX Characteristics Min. Typical Max. Unit 11g Target Power@6Mbps 14 15.5 17 dBm 11g Target Power@54Mbps 13 14.5 16 dBm fc +/- 11MHz - - -20 dBr fc +/- 20MHz - - -28 dBr fc > +/-30MHz - - -40 dBr -15 -1 +15 ppm 6Mbps - -30 -5 dBm 54Mbps - -31 -25 dBm Min. Typical Max. Unit 6Mbps (FER≦10%) - -92.5 -92.5 dBm 54Mbps (FER≦10%) - -76 -75.5 dBm Transmitter Output Power Spectrum Mask Frequency Error Constellation Error (peak EVM) RX Characteristics Minimum Input Level Sensitivity Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 10 EMW3090 Series Wireless Module Datasheet IEEE802.11n HT20 mode Table 14 RF Parameters in IEEE802.11n HT20 mode Item Description Mode IEEE802.11n HT20 Channel CH1 to CH13 Datarate MCS0/1/2/3/4/5/6/7 TX Characteristics Min. Typical Max. Unit 11n Target Power@MCS0 13.5 15 16.5 dBm 11n Target Power@MCS7 12 13.5 15.0 dBm fc +/- 11MHz - - -20 dBr fc +/- 20MHz - - -28 dBr fc > +/-30MHz - - -45 dBr -15 -1 +15 ppm MCS0 - -30 -5 dBm MCS7 - -32 -27 dBm Min. Typical Max. Unit MCS0 (FER≦10%) - -92.5 -92.5 dBm MCS7 (FER≦10%) - -73 -73 dBm Transmitter Output Power Spectrum Mask Frequency Error Constellation Error (peak EVM) RX Characteristics Minimum Input Level Sensitivity Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 11 EMW3090 Series Wireless Module Datasheet IEEE802.11n HT40 mode (MX1290V2 not support) Table 15 RF Parameters in IEEE802.11n HT40 mode Item Description Mode IEEE802.11n HT40 Channel CH3 to CH11 Datarate MCS0/1/2/3/4/5/6/7 TX Characteristics Min. Typical Max. Unit 11n Target Power@MCS0 13.5 15 16.5 dBm 11n Target Power@MCS7 12 13.5 15.0 dBm fc +/- 11MHz - - -20 dBr fc +/- 20MHz - - -28 dBr fc > +/-30MHz - - -45 dBr -15 -1 +15 ppm MCS0 - -30 -5 dBm MCS7 - -32 -28 dBm Min. Typical Max. Unit MCS0 (FER≦10%) - -92.5 -92.5 dBm MCS7 (FER≦10%) - -73 -73 dBm Transmitter Output Power Spectrum Mask Frequency Error Constellation Error (peak EVM) RX Characteristics Minimum Input Level Sensitivity Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 12 EMW3090 Series Wireless Module Datasheet Antenna Information EMW3090 has two specifications: PCB antenna and external antenna, please refer to the order code for order. IPX antenna connectors are not soldered on the modules using PCB antennas. By connecting an external antenna through an IPX connector, you can get better RF performance. PCB antenna parameters and use 4.1.1. On-board PCB parameter Table 16 On-board PCB parameter Item Min. Frequency 2400 Impedance Typical Max. Unit 2500 MHz 50 VSWR Ω 2 Gain ≤2dBi Efficiency >60% ordBi >-2.22dB Note: The above conditions are obtained with the module soldered to the motherboard and under anechoic chamber test conditions. Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 13 EMW3090 Series Wireless Module Datasheet Note: The above antenna test data is based on the module soldered to the test board with good clearance area in anechoic chamber conditions, the measured data is for reference only. In actual use, the antenna is affected by the whole structure and enclosure, the data will be deviated. PCB Antenna Clearance When using PCB antenna in Wi-Fi module, it is necessary to ensure that PCB and other metal devices are at least 16 mm away from the motherboard. The shaded areas in the figure below need to be far away from metal devices, sensors, interference sources and other materials that may cause signal interference. Figure 4 Antenna minimum clearance area (unit: mm) External antenna parameters and use Users can choose different 2.4G antennas with different external dimensions and gains not greater Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 14 EMW3090 Series Wireless Module Datasheet than 2dBi according to the application environment. When using an external antenna, it should be noted that the module must be powered on after the antenna is connected, because the module will perform IQ calibration after power on, and send a single carrier through the PA to pass the RX loop detection signal. If the load is not loaded (the antenna is not connected), it will cause calibration errors, which will make the PA output power abnormal, and a large standing wave will be formed at the PA output, which may damage the internal devices. The following is a copper tube antenna with an IPEX connector commonly used by MXCHIP: Figure 5 Copper tube antenna size ⚫ Frequency range: 2400-2500 MHz ⚫ Input impedance: 50 OHM ⚫ VSWR: < 2.0 ⚫ Gain:2.0DBI ⚫ Polarization: vertical ⚫ Directivity: Omnidirectional ⚫ Copper tube: 4.4 * 23mm ⚫ Wire: 1.13 gray wire L-82mm Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 15 EMW3090 Series Wireless Module Datasheet External antenna IPEX seat size: Figure 6 Dimension drawing of external antenna connector 4.3.1. SRRC Important statements The SRRC type approval number obtained for module models using an external antenna base has the (M) suffix and any module with the (M) suffix is specifically declared as follows. Type approval of a module does not imply that the end equipment in which the module is embedded or in which it is used complies with the relevant radio regulations or standards, and the end equipment manufacturer is responsible for the conformity of the technical characteristics of the product with the radio regulations or standards. Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 16 EMW3090 Series Wireless Module Datasheet Dimensions and Production Guidance Assembly Dimension Diagram Figure 7 Assembly Dimension Diagram(unit: mm, tolerance: ±0.1, outside tolerance±0.2) ) Recommended Package Drawing Figure 8 Package size (unit: mm) Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 17 EMW3090 Series Wireless Module Datasheet Reference Circuits Power The module uses 3.3V DC single voltage power supply. The following is an example of power supply after conversion with 5V power supply of USB interface. Figure 9 Power reference circuit Module basic circuit Figure 10 module basic circuit connection Note: The module has 100K hardware pull-up resistors in PA_30 (UART2_Log_TX) and PA_29 (UART2_Log_RX). The PA_0 pin has a 100K hardware pull-down resistor. CHIP_EN has an internal 100K pullup resistor and 0.01F capacitance to ground. Please pay special attention to the design schematic and PCB and allocate the pull-up and pull-down according to the internal hardware. UART During the debugging process, the UART signal is usually converted to USB and then connected to the PC. Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 18 EMW3090 Series Wireless Module Datasheet The conversion reference circuit is shown in Figure 11: Figure 11 USB to serial port reference circuit If the UART of the chip used by the user is 5V, you need to convert the 5V UART to 3.3V to communicate with the module. For the 5V-3.3V UART conversion circuit, please refer to the circuit shown in Figure 12. Figure 12 UART 3.3V/5V conversion circuit Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 19 EMW3090 Series Wireless Module Datasheet Production Guidelines MXCHIP stamp port packaging module must be SMT machine patches, module humidity sensitivity grade MSL3, after unpacking more than a fixed time patches to bake module. SMT patches require instruments ⚫ ⚫ ▪ Reflow bonding machine ▪ AOI detector ▪ 6-8mm suction nozzle Baking requires equipment: ▪ Cabinet oven ▪ Anti-static, high temperature tray ▪ Antistatic and heat resistant gloves The storage conditions of MXCHIP module are as follows: ▪ Moisture-proof bags must be stored in an environment with temperature < 30 degree C and humidity < 85% RH. ▪ A humidity indicator card is installed in the sealed package. Figure 13 Humidity Card After the module is split, if the humidity card shows pink, it needs to be baked. The baking parameters are as follows: ▪ The baking temperature is 120℃±5℃ and the baking time is 4 hours. ▪ The alarm temperature is set to 130℃. ▪ SMT patches can be made after cooling < 36℃ under natural conditions. ▪ Drying times: 1 time. ▪ If there is no welding after baking for more than 12 hours, please bake again. If the disassembly time exceeds 3 months, SMT process is forbidden to weld this batch of modules, Copyright of Shanghai MXCHIP Information Technology Co., Ltd. 20 EMW3090 Series Wireless Module Datasheet because PCB gold deposition process, over 3 months, pad oxidation is serious, SMT patch is likely to lead to virtual welding, leak welding, resulting in various problems, our company does not assume the corresponding responsibility. Before SMT patch, ESD (Electrostatic Discharge, Electrostatic Release) protection should be applied to the module. SMT patches should be made according to the reflow curve. The peak temperature is 250 C. In order to ensure the qualified rate of reflow soldering, 10% of the first patches should be taken for visual inspection and AOI testing to ensure the rationality of furnace temperature control, device adsorption mode and placement mode, and 5-10 patches per hour are recommended for visual inspection and AOI testing in subsequent batch production. Precautions ⚫ Operators of each station must wear static gloves during the entire production process. ⚫ Do not exceed the baking time when baking. ⚫ It is strictly forbidden to add explosive, flammable, or corrosive substances during baking. ⚫ When baking, the module uses a high temperature tray to be placed in the oven to keep the air circulation between each module while avoiding direct contact between the module and the inner wall of the oven. ⚫ When baking, please close the oven door to ensure that the oven is closed to prevent temperature leakage and affect the baking effect. ⚫ Try not to open the door when the oven is running. If it must be opened, try to shorten the time for opening the door. ⚫ After baking, the module should be naturally cooled to
113990976 价格&库存
很抱歉,暂时无法提供与“113990976”相匹配的价格&库存,您可以联系我们找货
  • 1+27.539441+3.56160
库存:28
