GrovePi Zero(GrovePi0)
SKU 114020001
Description
The GrovePi Zero makes electronics prototyping with the Raspberry Pi Zero easy and fast. The
powerful little Raspberry Pi Zero is just waiting for you to release your maker creativity and
build the projects you’re passionate about. With the GrovePi Zero you can start your connected
device projects in minutes.
The GrovePi Zero simplifies making your project: there are no more jumpers, no more
breadboards, and no more loose parts to bring your Internet of Things devices to life.
You can use the hundreds of sensors offered in the Grove module family: everything from a
distance sensor, light sensor, temperature and humidity sensor, buttons, and displays. There
are literally hundreds of electronic modules for your project!
The GrovePi Zero has 6 ports. GrovePi Zero has a compact form factor, making your design
small. The design fits neatly over the Raspberry Pi Zero.
Note:
GrovePi Zero will NOT work with the original Raspberry Pi Model A & Raspberry Pi Model B
The Raspberry Pi Zero comes without pins installed, so if you want to connect the GrovePi Zero
to the Raspberry Pi Zero, you will need to solder the pins to the Raspberry Pi Zero.
Technical Details
Dimensions
85mm x 29.5mm x 23.5mm
Weight
G.W 22.3g
Battery
Exclude
Analog Ports
2
Serial Port
1
Digital ports
2
Part List
GrovePi Zero Board
1
https://www.seeedstudio.com/GrovePi‐Zero%EF%BC%88GrovePi0%EF%BC%89‐p‐3011.html 12‐12‐17
很抱歉,暂时无法提供与“114020001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+226.3347510000+29.02987
