114020141
114020141
    SEEED(矽递科技)
    GROVE THERMAL CAMERA 55 DEGREE
114020141 数据手册
Grove - Thermal Imaging Camera / IR Array MLX90640 55 degree SKU 114020141 Grove - Thermal Imaging Camera is a thermal sensor which carries MLX90640 IR Array. The camera can present dynamic thermal images and detect the surrounding temperature from -40℃~300℃. The camera with narrow-angle has an FOV of 55°x35 °. Note If you would like to use a wide-angle of IR thermal camera, please take a look at Grove - Thermal Imaging Camera / IR Array MLX90640 110 degree. Key Features • • • • IR Thermal Sensor Array 32X24(MLX90640) 55°x35° FOV(field of view) Temperature measurement range:-40℃~300℃ I2C Grove interface Description Looking for a thermal sensor which can detect your surround temperature? This IR thermal camera can not only measure the value of temperature around you but also display the thermal imaging figure. So it must be your best choice to monitor the temperature change from this tiny camera. The IR thermal camera carries a 32x24 array of thermal sensors (MLX90640), it can detect the temperature of objects from feet away with the accuracy of ±1.5℃. In order to obtain the thermal image easily, I2C protocol is used to get the low-resolution image from the camera. The FOV(Field of View) of this camera is 55°x35°, and the temperature measurement range is -40℃~300℃. This module connects the MCU with the I2C interface. However, it needs an MCU which has over 20000 bytes of RAM to drive the camera. As a matter of fact, Dev board like Arduino Uno can not be used with this Sensor camera due to its lower ability of calculation. We recommend you to choose Arch Mix as an MCU to control the camera because it really has an excellent performance to process the complex data from the IR sensor camera. Specification Items Values Operating Voltage 3V-3.6V Current Consumption ~18mA Field of View 55°x 35° Measurement Range -40°C-300°C Resolution ±1.5°C Refresh Rate 0.5Hz-64Hz Interface I2C Grove interface I2C Address 0x33 Part List • 1*Grove - Thermal Imaging Camera / IR Array MLX90640 55 degree Note This product has a Grove interface which needs Grove Cable to connect with. ECCN/HTS HSCODE 9031900090 UPC https://www.seeedstudio.com/Grove-Thermal-Imaging-Camera-IR-Array-MLX90640-55-degree-p-4335.html/12-9-19
114020141
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路。
3. 引脚分配:共有6个引脚,分别为1脚发光二极管阳极,2脚发光二极管阴极,3脚光电晶体管发射极,4脚光电晶体管集电极,5脚光电晶体管基极,6脚光电晶体管发射极。
4. 参数特性:工作温度范围为-40℃至+85℃,输入电流为10mA,输出电流为10mA。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强,响应速度快等特点。
6. 应用信息:广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:采用DIP6封装形式。
114020141 价格&库存
很抱歉,暂时无法提供与“114020141”相匹配的价格&库存,您可以联系我们找货
