114090001
114090001
    SEEED(矽递科技)
    MBOT EXPANSION PACK SIX LEGGED
114090001 数据手册
mBot Add‐on Pack ‐ Six‐legged Robot SKU 114090001 mBot six-legged robot is a 3-in-1 expansion pack based on mBot. You can construct "Beetle", "Mantis" and "Crazy Frog" with mBot and the parts inside the pack. The mBot six-legged robot makes mBot more vivacious and enjoyable. Description What is mBot six-legged robot? mBot six-legged robot is a 3-in-1 expansion pack based on mBot. You can construct "Beetle", "Mantis" and "Crazy Frog" with mBot and the parts inside the pack. The mBot six-legged robot makes mBot more vivacious and enjoyable. Let's get your six-legged robot move! Shape one: Beetle A six-legged beetle that moves quickly. It turns around and attacks the enemy promptly! Shape two: Mantis It quietly crawls, waving two arms disposedly. It is the hunter from the darkness, approaching you, and catching you… Shape three: Crazy Frog A little crazy frog, dashes around so madly that, nobody can stop it. Example: Specifications Model mBot six-legged robot Type Expansion pack Weight 255g (8.99oz) Outer packing size 100×60×150mm (length×width×height) Part List 6 × Screw M4 x 8mm 8 × Screw M4 x 14mm 8 × Screw M4 x 22mm 4 × Screw M4 x 30mm 4 × Screw M4 x 35mm 8 × NutM4 16 × Lock Nut M4 12 × Plastic Spacer 4 x 7 x 10mm 14 × Plastic Spacer 4 x 7 x 3mm 24 × Rivet 2 × Beam0412-108-Blue 2 × Beam0412-092-Blue 6 × Beam0412-076-Blue 2 × Beam0412-060-Blue 2 × Plate 45°-Blue   Copyright © 2008-2016 Seeed Development Limited All rights reserved
114090001 价格&库存
很抱歉,暂时无法提供与“114090001”相匹配的价格&库存,您可以联系我们找货
