JGA25‐370 Geared Motor
SKU 114090046
Please use this motor as an alternative to JGB37‐371 and Encoder Geared Motor JGA25‐371
What is the Geared motor?
The geared motor uses a gear set to convert the original high speed and low torque of the motor to
a low speed and high torque state. So what are the benefits of geared motors? Under the same
voltage conditions, you can manually clamp the motor to stop it, but once it is a gear motor, it is
more difficult to stop the motor with an external force because the "force" of the motor becomes
larger. Therefore, when you use a geared motor, you will find it is slower than a motor that does not
slow down, but it can provide a larger load. Geared motors are typically used where high torque is
required, such as an elevator, which will carry more than a dozen people upstairs, which will
require a lot of torque. Of course, there will be some energy loss during deceleration, but it will still
bring a lot of convenience to our lives.
Introduction:
This Motor not encoder, Mainly used in robot platform and car provides power, Good
quality and long lifetime, high torque and low noise.
If you need an encoder, you can choose JGA25‐371 Geared Motor with Encoder.
Specification:
Voltage
V
Maximum efficiency pointed
No‐load
Blockage
speed
r/min
electric
current
A
speed
r/min
electric
current
A
Torque
Kg.cm
Power
W
Torque
Kg.cm
electric
current
A
6
190
0.2
133
0.5
0.75
1.1
4.0
2.1
12
350
0.1
245
0.65
1.4
2.4
5.2
2.2
size:
Part List
1 x JGA25‐370 Geared Motor
ECCN/HTS
ECCN
ERA99
HSCODE
8501101000
UPC
https://www.seeedstudio.com/JGA25‐370‐Geared‐Motor‐p‐4119.html/8‐14‐19
很抱歉,暂时无法提供与“114090046”相匹配的价格&库存,您可以联系我们找货
